newbie question....
Forum topic by westside posted 11-23-2009 03:20 AM 1016 views 0 times favorited 4 replies Add to Favorites Watch
View westside's profile
westside
77 posts in 3355 days
11-23-2009 03:20 AM
I have heard and read about using a “scraper” instead of sanding. What is a scraper and how do you use it? Can you find it in a big box store or a woodworking store?
Thanks in advance
View lew's profile
lew
12510 posts in 3995 days
#1 posted 11-23-2009 03:26 AM
Check this out http://lumberjocks.com/toddc/blog/11542
View dustbunny's profile
dustbunny
1149 posts in 3535 days
#2 posted 11-23-2009 03:38 AM
I just bought a set from Rockler.
They are used to remove milling marks from your wood.
It’s kind of like if you have ever scraped anything with a razor blade, removes fine layer of wood surface.
Only bigger and better.
Sometimes nothing else is needed to “smooth” the surface of your wood.
Here is a link-
http://www.rockler.com/product.cfm?page=4898&filter=scrapers
and a video by fellow LJ Todd Klippinger-
http://www.youtube.com/watch?v=d3sqDWFAA0s
Lisa
-- Imagination rules the world. ~ Napoleon Bonaparte ~ http://quiltedwood.com
27250 posts in 4061 days
#3 posted 11-23-2009 04:49 AM
One note I would add is that while I do use a scraper I do not use it to avoid sanding. Sanding is an integral part of the preparation process. Scraping is the first step in preparing raw wood for finish. Its advantage is that it removes mill marks much faster than sanding but it does not replace sanding. You will still have to go through the sanding process to prepare the wood for finish.
View PurpLev's profile
PurpLev
8548 posts in 3888 days
#4 posted 11-23-2009 05:28 AM
like Scott said – scraping has it’s place, and although it can reduce sanding significantly, it does not necessarily replace it completely. Scraping can replace the sanding process during joinery, and glue up, but in order to finish a piece – you’ll still have to sand it.
there’s a time and place for everything.
with that said – I do recommend learning to scrape, as it will help you avoid sanding prior to the finishing process.
