What is this collar on my blade heigh shaft?
Forum topic by lateralus819 posted 09-20-2015 12:51 AM 670 views 0 times favorited 5 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1883 days
09-20-2015 12:51 AM
I noticed this collar on the shaft for the blade height adjustment mechanism. It has two threaded holes for set screws.
The screws are missing and it’s just sitting there. What is it’s function? It seemed to be next to the pulley for the motor. Any ideas?
5 replies so far
View TheFridge's profile
TheFridge
9435 posts in 1479 days
#1 posted 09-20-2015 12:53 AM
What kind of saw?
View MrUnix's profile
MrUnix
6695 posts in 2192 days
#2 posted 09-20-2015 12:56 AM
From what I can see… looks fine :)
lateralus819
#3 posted 09-20-2015 02:37 AM
Its a Grizzly G1023 99’ model. I guess i should have grabbed a picture. I can see where the shaft is “clean” where it was, but it is touching the motor pulley so I’m not sure if thats the original spot or not.
MrUnix
#4 posted 09-20-2015 03:25 AM
Is the clean spot at the back end of the shaft right next to where it goes through the support casting? If so, put it back and secure it with the set screws. It keeps the shaft captive and without it, your elevation adjustment will be loose and subject to unintended movement.
lateralus819
#5 posted 09-20-2015 04:13 AM
No, actually. It was stationary next to (and rubbing on) the belt pulley off the motor. Glad I cought it.
I’ll have to figure out the size of the set screws and purchase more. They’re both missing. I feel it may have been like this long before I bought it. I never messed with it when I rebuilt it. Thanks for the image. I found the manual.
