Table saw set up
Forum topic by jayvansickle posted 09-19-2015 10:09 PM 1053 views 0 times favorited 18 replies Add to Favorites Watch
View jayvansickle's profile
jayvansickle
25 posts in 1103 days
09-19-2015 10:09 PM
Does anybody make a 10” table saw blade with no teeth to use as a set up tool? To be used to square the blade to table, blade to fence, etc.
-- If a parsley farmer goes broke, can they garnish his wages
18 replies so far
View TravisH's profile
TravisH
583 posts in 1962 days
#1 posted 09-19-2015 10:24 PM
I guess I don’t see the big plus in having one? Seams like just adding an extra step into doing something. I would be more inclined to just buy some plexiglass or acrylic and make one, or use a scrap of hardboard, etc…
jayvansickle
#2 posted 09-19-2015 10:27 PM
Excellent idea. Thank you. Sometimes the obvious eludes me (hah).
View Redoak49's profile
Redoak49
3287 posts in 2016 days
#3 posted 09-19-2015 11:41 PM
Yes, they do make table saw alignment plates that are very accurate or is it precise or something.
I mark a tooth on a blade for alignment but might be wondering how flat plexiglass or hardboard would be.
View Gentile's profile
Gentile
306 posts in 1846 days
#4 posted 09-20-2015 01:35 AM
Sears/Craftsman made a disc to turn a table saw into a sander. I recall it being made of thick steel, 3/16 to 1/4” or so
I wonder if that would work?
-- "I cut it twice and it's still too short"
View hotbyte's profile
hotbyte
991 posts in 3003 days
#5 posted 09-20-2015 01:54 AM
Google table saw alignment disk and you will get several options. Never used any of them myself.
View TheFridge's profile
TheFridge
9608 posts in 1513 days
#6 posted 09-20-2015 02:02 AM
Check Forrest. No offense, but I think it’s a waste of money.
View OhioMike's profile
OhioMike
79 posts in 2190 days
#7 posted 09-20-2015 02:03 AM
Rockler sells the MASTER PLATE for $50
I don’t own one. I just mark a tooth on a high-quality blade and measure to it.
Mike
View Andrew Betschman's profile
Andrew Betschman
309 posts in 3250 days
#8 posted 09-20-2015 02:04 AM
runswithscissors
2767 posts in 2052 days
#9 posted 09-20-2015 04:42 AM
Grizzly has one.
View MrUnix's profile
MrUnix
6767 posts in 2226 days
#10 posted 09-20-2015 04:47 AM
Seems like one of those things that you would use once and then put away, not to be touched again for another few years – at which point you will have forgot where you put it, so you just square up the blade the normal way like you always have :)
View Woodknack's profile
Woodknack
11813 posts in 2407 days
#11 posted 09-20-2015 05:12 AM
- Redoak49
Accurate.
Precise = repeatability
Redoak49
#12 posted 09-20-2015 12:55 PM
If I remember accurately, the plates used are precise as the measurements all over the plate are very close together.
View johnstoneb's profile
johnstoneb
2942 posts in 2200 days
#13 posted 09-20-2015 01:34 PM
x1 The Fridge and Ohio Mike
-- Bruce, Boise, ID
View oldnovice's profile
oldnovice
6901 posts in 3395 days
#14 posted 09-20-2015 04:47 PM
Is all that really necessary?
If you have a decent blade you can check the run out on that and then use it for aligning the saw itself.
I feel that those “extra” set up plates just cost “extra” money!
View toolie's profile
toolie
2134 posts in 2656 days
#15 posted 09-21-2015 01:56 PM
I bolted a piece of 3/4” mdf to an arbor and it worked just fine. I’ve also used a 10” blade and gotten both blade and fence aligned to the same miter slot +/- .001”.
