hand held power planer
Forum topic by dbw posted 09-19-2015 08:00 PM 1519 views 0 times favorited 24 replies Add to Favorites Watch
View dbw's profile
dbw
201 posts in 1633 days
09-19-2015 08:00 PM
Topic tags/keywords: hand held power planer
What do folks think of those 3 1/4” wide hand held power planers as compared to a traditional hand tool.
-- measure 3 times, cut once
24 replies so far
View JoeinGa's profile
JoeinGa
7736 posts in 2003 days
#1 posted 09-19-2015 08:33 PM
I have a Makita that I dont use near as much as I could. Just the other day somebody showed how he uses it to sorta “round out” bowl blanks for turning and I thought that was pretty good idea. I’ll probably be using it more and more now.
View Texcaster's profile
Texcaster
1281 posts in 1670 days
#2 posted 09-19-2015 09:29 PM
The power planer is primarily a carpenter’s site tool, however it can be used in the workshop. Mine is used with winding sticks to rough dress slabs. In the link the plane has fresh cutters and is set on a “vapor” cut.
http://lumberjocks.com/Texcaster/blog/53473
off topic : The photos show sprung joint, one bolt end caps.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View BurlyBob's profile
BurlyBob
5491 posts in 2262 days
#3 posted 09-19-2015 11:36 PM
pretty much a waste of money. Wonder what the heck I was thinking? Bought the same Mikita POS shown above. Makita is right up there with crapsmen in my book.
View dhazelton's profile
dhazelton
2767 posts in 2293 days
#4 posted 09-19-2015 11:48 PM
I have a Makita circular saw and 3 of their sanders (one of them is 30 years old and sees plenty of use). And a grinder. And a drill. None of those tools are crap.
I’ve used a power planer mainly to fit doors to out of square openings in older homes. Handplanes work just as well, just slower. But that can be a benefit in that you don’t remove too much like you can with a power planer.
View AlaskaGuy's profile
AlaskaGuy
4131 posts in 2306 days
#5 posted 09-20-2015 04:05 AM
I ve used a power planer mainly to fit doors to out of square openings in older homes. Handplanes work just as well, just slower. But that can be a benefit in that you don t remove too much like you can with a power planer.
- dhazelton
Well BurblyBob is just a little confused about Mikita tools.
Many people have problems using the electric hand plane cause they can take a little skill to use them. I suspect BurblyBob hasn’t use one much.
View tomd's profile
tomd
2155 posts in 3767 days
#6 posted 09-20-2015 04:38 AM
I bought a hand held power planer, what was I thinking ?
-- Tom D
View Mark Wilson's profile
Mark Wilson
2124 posts in 1060 days
#7 posted 09-20-2015 06:47 AM
That wacky piece of wood that won’t let your lathe stand still can be convinced into a more-spinnable shape with a little judicious shaving here and there. I’ve seen the same tool used to great effect by one of the masters of sculpted furniture, as well. It’s a lot less messy than an angle grinder or a chainsaw – just hook up a Shop Vac hose. Also, I turn mine upside-down, held in a handscrew clamp, clamped to my workbench, and use it as a small jointer.
-- Mark
View Kelly's profile
Kelly
2025 posts in 2941 days
#8 posted 09-20-2015 07:44 AM
I use mine to cut hours off the labor on a project. I’ve used it on slabs, deck joints, when one rose above the other, for door, for knocking the edge off a pieces of lumber (e.g., working a forty-five) and so on. It’s a valued tool in my shop.
dhazelton
#9 posted 09-20-2015 11:52 AM
@ Mark Wilson. Please tell me you have all your digits. If they made a little pork chop for it I could see doing that, otherwise I’m too much of a sissy.
Actually, mounting it in some kind of box with a springy pork chop might be a cool thing to have on a jobsite.
View dbw's profile
dbw
#10 posted 09-20-2015 03:31 PM
What is a “springy pork chop”?
View xmastree's profile
xmastree
47 posts in 977 days
#11 posted 09-20-2015 03:37 PM
Even my cheesy Bosch hand planer has come in mighty handy. And if Makita makes a tool that is anything less than top-notch, I haven’t seen it yet.
-- Every tree is a Chistmas tree with its gifts hidden inside.
View Stewbot's profile
Stewbot
199 posts in 1080 days
#12 posted 09-20-2015 05:05 PM
Pretty darn handy when fixing wonky walls. Never thought to find a use for it in the shop.
-- Hoopty scoop?
View Bluepine38's profile
Bluepine38
3379 posts in 3082 days
#13 posted 09-20-2015 05:25 PM
I had sold them to log home builders who used the heck out of them, never thought about one for my shop,
guess, I will have to take another look at them.
View shipwright's profile
shipwright
7980 posts in 2794 days
#14 posted 09-20-2015 06:11 PM
They are one of the real workhorse tools in wood boatbuilding. There is no better tool for shaping deck beams, timbers, and many other things, even planking.
However the short, consumer models I see around these days are not likely up to the challenge of long hours of heavy use.
This was the standard of the industry when I was building. It’s a Skill 100. I haven’t seen it’s match lately.
View Lynden's profile
Lynden
74 posts in 3143 days
#15 posted 09-20-2015 06:25 PM
I have the Makita pictured above. I’ve used it mainly to flatten walls, ceilings and floors by taking the high spots off of studs and joists. Have also used it on door edges. Makita sells a dust port that fits a shop vac hose. It’s a replacement for the oval port that comes with the older planers.
http://www.makita.com.au/products/accessories/planers-accessories/192082-7-dust-extraction-nozzle-1911b
