Using Table Saw for A-Typical cuts
Forum topic by markum posted 09-19-2015 01:02 PM 800 views 0 times favorited 7 replies Add to Favorites Watch
View markum's profile
markum
6 posts in 1181 days
09-19-2015 01:02 PM
In the process of making bracket feet for a small spice cabinet, on my table saw, I am having trouble with the results. I used the online calculator for the blade tilt and fence angle. The problem is the apex is in the wrong direction. I entered minus 0.025 for the offset, but the calculator won’t take a negative number and I don’t know how to shift the apex to the left. If I change the fence angle from 71 degrees to 21 degrees, my fence will be right to left but the blade is tilted left so the fence should be left to right. It looks to me like the apex (the left line) is the center of the circle and I have it set at the center of the ellipse. Any comments?
7 replies so far
16274 posts in 4181 days
#1 posted 09-19-2015 01:15 PM
Maybe you could post some photos or a drawing. I think most folks (like me) are going to have a hard time visualizing what you’re describing.
View roderick's profile
roderick
18 posts in 1738 days
#2 posted 09-19-2015 02:45 PM
I have the identical problem I have a photo How do I upload it?
-- just doug
117060 posts in 3540 days
#3 posted 09-19-2015 02:51 PM
roderick
Above the comment section aka “have your say”click on the “IMG” square then “CHOOSE FILE”and select a file and photo,then click on “INSERT THIS IMAGE”
roderick
#4 posted 09-19-2015 03:05 PM
I hope these got uploaded. Sure hope somebody can help us. Markum I think your offset should be .250. I think we’re working on the same spice cabinet? From American Woodworker Feb 1994 #36?
-- just doug
#5 posted 09-19-2015 03:13 PM
It looks like if you ran the stock the opposite direction you would have the arch you want,if that doesn’t work try hot glueing a strip to one side of the stock to raise it up on one edge.
roderick
#6 posted 09-19-2015 06:42 PM
the template id is width of cove ( 1 5/8”) od is height of foot (2 5/8 “)
fence angle is 71 degrees
You are right Jim. The blank is rougher than the first cut. I had to move the fence to register the 1/4 ” margin on the left instead of right and the start/ stop points are not the same. I’m making a pine prototype and a cherry finished spice cabinet. So far I’ve made all the mistakes on the proto. Thanks for your help
-- just doug
roderick
#7 posted 09-22-2015 03:36 PM
Update. I switched to a 7 1/4” – 40 tooth blade. New settings are fence angle 67 degrees, blade tilt 28 degrees. I used a slightly wider blank. This time I set the fence so that just the left side just touched the upcoming tooth and set the angle. On the previous try I set the fence so both the upcoming and downward teeth just touched the blank. The fence angle was always off. Here is the result. I haven’t used a scraper yet this is right off the saw table.
-- just doug
