Setting Down a ROS
Forum topic by SPalm posted 11-21-2009 10:57 PM 1100 views 0 times favorited 4 replies Add to Favorites Watch
View SPalm's profile
SPalm
5317 posts in 3844 days
11-21-2009 10:57 PM
Topic tags/keywords: trick tip sander
I just finished a bit of sanding. There were some parts that needed flipping and exchanging. I was getting frustrated with the age old problem of waiting for the sander to totally stop before putting it down on the bench. I had seen the LJ discussion of using a plastic top of a coffee can. This works ok, and I keep two of them on the bench. But I always end up with putting other small things in them and using them as parts trays. (This is ok in its own right.)
But I just came up with a neat solution. Take another ROS disk, turn it upside down and use it for a landing pad. It could be a used pad or a new one. The hook and loop side is real soft and will not damage the bench top, while the sandpaper side grabs onto the sander. Whenever I am sanding, there are always spare disks nearby.
I don’t know. Give it a try.
Steve
-- -- I'm no rocket surgeon
117060 posts in 3539 days
#1 posted 11-21-2009 11:06 PM
Interesting idea
View jockmike2's profile
10635 posts in 4208 days
#2 posted 11-21-2009 11:27 PM
Yea, don’t sound to unsound. m
16274 posts in 4180 days
#3 posted 11-21-2009 11:44 PM
I’ll give it a try for sure. I’ve been toying with buying one of those “sander sitters”, but free is even better.
35111 posts in 4362 days
#4 posted 11-22-2009 01:14 AM
You could make a Small Lazy Larry and put a sanding disk on top of that and let the whole thing Jiggle.
But that is a neat idea Steve.
