Delta 14" Bandsaw Trunnion Question
Forum topic by onoitsmatt posted 09-18-2015 08:09 PM 682 views 0 times favorited 2 replies Add to Favorites Watch
View onoitsmatt's profile
onoitsmatt
389 posts in 1145 days
09-18-2015 08:09 PM
I am working on restoring an old Delta/Milwaukee 14” band saw. I was taking apart the trunnions today and found this one looks like it has been ground down from use. I am wondering if this is how it is supposed to look or if this is something that’s going to give me issues getting the table set up flat/straight/true/plum/etc.
Thanks (as always) for any info you can provide!
Matt Singleton
Phoenix,AZ
-- Matt - Phoenix, AZ
2 replies so far
View MrUnix's profile
MrUnix
6609 posts in 2168 days
#1 posted 09-18-2015 08:24 PM
From that picture, it looks fine. The support bracket (what you show in the picture) is cast iron, while the trunnions are a much softer die cast material – so the trunnions would wear down before the support bracket ever would. The supports are not the same thickness though, so maybe that is what made you think it was worn down:
onoitsmatt
#2 posted 09-18-2015 09:07 PM
Thanks Brad! Glad to hear it’s not busted!
