Where can I get PVC/Ductwork for dust collector?
Forum topic by BarryAbrams posted 09-18-2015 04:53 PM 1058 views 0 times favorited 7 replies Add to Favorites Watch
View BarryAbrams's profile
BarryAbrams
1 post in 980 days
09-18-2015 04:53 PM
I’ve a new owner of a Harbor Freight Dust Collector. I’m interested in installing piping in my workshop to hook up a couple of the tools to it.
From what I’m reading hear and other places, I should install a 5 or 6” PVC or metal duct from the DC most of the way, then branch off to 4” to the tools creating the dust. I plan on modifying the HF DC with the usual upgrades: a Wynn Filter and some sort of separator. What’s the maximum length of a run I should attempt? I can get the run to be pretty straight… all the tools are mostly in a diagonal line.
Where can I buy 5” or 6” PVC? I’ve been to all the big box stores around me, but none of them really have anything over 4”, and all of it’s schedule 40. I can’t find any schedule 20 stuff.
7 replies so far
View splintergroup's profile
splintergroup
2011 posts in 1220 days
#1 posted 09-18-2015 04:58 PM
I had to look far and wide for 6” PVC. I first went to a plumbing supply house, which did not sell to the ‘public’. They did however point me to the place they got their large PVC from (which I would never had found otherwise).
If you strike out on the Sched 20 PVC, you should consider HVAC duct. Not as easy to work with as PVC, but given your main trunk line mostly being straight, it would be do-able. A significant portion of my 2HP cyclone system is done with 6” metal duct.
4985 posts in 2491 days
#2 posted 09-18-2015 05:48 PM
You won’t find 5” PVC, and like Splintergroup said the 6” isn’t all that easy to come across. If you have Menard’s in the area, they carry the 3034 which is a bit heavy for ducting, but it will work and goes on sale sometimes for about $20/10’. What you really want is ASTM 2729 and it have 1/2 dozzen names to describe it. A plumbing supply (like Hughes Supply) may have it, or try the HVAC. the biggest problem with it may be finding wyes instead of tees.
View AZWoody's profile
AZWoody
1330 posts in 1222 days
#3 posted 09-18-2015 05:52 PM
Not sure but you might want to make sure the HF dust collector can move enough air to be able to use 6” ducting.
If the volume is not high enough, the velocity inside ducting that size will slow down and it will become ineffective.
splintergroup
#4 posted 09-18-2015 08:00 PM
- AZWoody
True dat!
Another consideration for the HVAC plumbing is the accessories (wyes, ells, etc.) are designed for air flow.
View rwe2156's profile
rwe2156
2925 posts in 1478 days
#5 posted 09-18-2015 11:48 PM
Find a commercial plumbing suppy that will sell to a cash customer.
Or
Make friends with a plumber who can order it under his account.
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#6 posted 09-19-2015 12:11 AM
What about sewage and drainage pipe? Right diameter, cheap, lot’s of options as far as elbows and wyes and such. look in HD or Lowes, comes in solid or the kind with holes for the bottom of french drains.
View WoodES's profile
WoodES
96 posts in 1689 days
#7 posted 09-19-2015 03:06 AM
I bought 6” drainage pipe and fittings from a landscape supplier. It is light material, but plenty for the 2hp DC that I have.
