Need help sourcing a tool/method of work
Forum topic by ardbeg posted 09-17-2015 08:58 PM 802 views 0 times favorited 5 replies Add to Favorites Watch
View ardbeg's profile
ardbeg
102 posts in 3265 days
09-17-2015 08:58 PM
Topic tags/keywords: jig tablesaw clamp blade router
I need to put slots (through mortises) in basswood rails which are anywhere from 18” to 108” long, 3/4 thick, and 1 1/2 to 5 1/2 wide. Slots are 1/4”x 3”. 2 to 4 per rail. The slots are located by the ends and occasionally in the center if the rail is long. They need to be repeatable and done 20+ an hour. This is in a production environment. I was hoping a woodrat might work, but doesn’t seem like it will.
In essence, I need to cut a bunch of through mortises quickly and somewhat precisely in a way that is repeatable and straightforward.
Any thoughts?
-- You may delay, but time will not. --Ben Franklin
5 replies so far
View Dallas's profile
Dallas
3599 posts in 2725 days
#1 posted 09-17-2015 09:01 PM
cnc
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#2 posted 09-17-2015 09:09 PM
Sounds like you need a chain mortiser. Here's one.
-- Bondo Gaposis
View jerryminer's profile
jerryminer
944 posts in 1679 days
#3 posted 09-18-2015 05:15 AM
Slot mortiser. Multi-Router. Wirth Machine
View JAAune's profile
JAAune
1854 posts in 2554 days
#4 posted 09-18-2015 06:31 AM
A custom-built CNC horizontal router would do the trick. One two axis movement required so it’s not a difficult build.
Slot mortisers as others have mentioned are also well-suited for this type of work.
View Woodknack's profile
Woodknack
12464 posts in 2618 days
#5 posted 09-18-2015 07:12 AM
Can you get router bits or mortising chisels that will cut 5.5” deep mortises? And why would you need CNC, that seems like an unnecessary complication.
