What do you use to clean your table saw blades?
Forum topic by SC_Galoot posted 627 days ago 2262 views 2 times favorited 22 replies Add to Favorites Watch
View SC_Galoot's profile
SC_Galoot
13 posts in 633 days
627 days ago
I desparately need to clean my ts blade. I’m looking for some old time “home remedies” which use ingredients that I might have lying around the house and didn’t know about. I know I can go out and buy Rockler’s Pitch and Resis Remover and have heard many positive recommendations for it. But, barring that or any of the other commercial products, what else could I use? Perhaps mineral spirits or maybe turpentine? What about rubbing alcohol? Would these hurt the blade or the carbide tips?
Thanks for your ideas.
View TomFran's profile
TomFran
2465 posts in 745 days
627 days ago
If you are close to a Woodcraft Supply, they sell a very good product for cleaning blades. I bought a gallon of it several years ago and still have some. Of course you could order it online if there isn’t one nearby.
SC_Galoot
627 days ago
The closest Woodcraft to me is in Charleston – about 2 hours away. There is a WoodZone and Rockler outlet in town that I can easily buy cleaner at. However, I’m trying to avoid spending any money unless absolutely neccessary. I’m interested in ways of cleaning the blade using everyday household items. Any ideas would be welcome.
View Fingersleft's profile
Fingersleft
71 posts in 647 days
627 days ago
Hi Galoot -
If you’re looking for household cleaners, I’ve used Goop and a clean rag. Seems to take most of the tar and stuff off the blade, and I don’t think there’s anything in there that can hurt the blade or the tips.
-- Bob
View Dekker's profile
Dekker
145 posts in 631 days
627 days ago
Mineral spirits or turpentine, depending on what is gooping your blade… I’ve had great results with both. It also works for router bits.
-- Dekker - http://www.WoodworkDetails.com/Blog/MNagy/
View cassy's profile
cassy
27 posts in 783 days
627 days ago
I have feard of people using oven cleaner,be sure your outside spray it on wait a couple of minutes,then with a scrubbing brush when all is clean just rinse it off with water and dry the blade. Hope this helps.
-- dave montreal
View USCJeff's profile
USCJeff
864 posts in 819 days
627 days ago
Just a heads up Dan, don’t use a degreaser. Most all degreasers (oven cleaner for example) contain a chemical that can break down the bonding of the carbide teeth. Something about carbide teeth flying through my shop gives me the willies. I believe it was Marc Spag that suggested using “little green” cleaning solution. We have it on hand for our little spot carpet cleaner. Soak the blade, and then brush off the resin. It can be reused many times. I also have a couple store bought preventative products I purchased locally. Mann Tool has a 3-pack of Boeshield products for about $30. It contains a preventative spray, a rust removal spray, and a blade and bit cleaner. Since you’re shops aobut 100’ from mine, feel free to borrow some little green if you want to test it before buying. Go to the WoodWhisperer site and watch the most recent podcast. Can’t remember the title. It’s the one in which Marc is doing maintanence after a project. He goes through the cleaning process. Video is worth many words!
-- Jeff, South Carolina
View Dadoo's profile
Dadoo
1674 posts in 741 days
627 days ago
I did a forum on this about a month ago. Go read it. I used Acetone and a soft brass wire brush…Was very pleased with the results.
http://lumberjocks.com/topics/941
21154 posts in 1151 days
627 days ago
I thought I remember someone using citric acid to clean rust and I thought they also said it cleaned the blade.
-- Karson Southern Delaware karson_morrison@bigfoot.com †
View WayneC's profile
WayneC
5774 posts in 848 days
627 days ago
I used citric acid to clean plane blades and bodies. Not tried it on saw blades.
View RickL's profile
RickL
77 posts in 691 days
626 days ago
SC, I see you have a lot of choices but of all of the things I have tried, good old 409, a cheap rimmed baking sheet, and a brass brush work every time. I soak the TS blade in the pan for 5 to 10 minutes, bush, dry, and it is ready to go.
-- Rick, Jackson, TN "Do What You Like. Like What You Do" Life Is Good
dennis mitchell
3703 posts in 1065 days
623 days ago
Been using oven cleaner for years. Still have all my teeth. Only clean um once a year or so anyway.
View scottb's profile
scottb
3338 posts in 1078 days
623 days ago
I’ve used Simple Green, or any similar cleaners from the “organic” section of the supermarket. Works great with the scrubby side of a sponge.
View Alin Dobra's profile
Alin Dobra
317 posts in 639 days
623 days ago
Simple Green, as Scott mentioned, works very well. I read this on the web about 2 years back (lots of people experimented with it). It is known not to cause any problems with the welding of the carbide teeth to the blade. I used it to clean both table saw blades and router bits and it works really well. I usually scrub with an used toothbrush. I usually do not bother to take the blade down (my father managed to drop a blade on the floor and bend a teeth; since then I clean them in place).
I would personally not bother with a specialized product since Simple Green is so good and is so much more cost effective (and you can use it to clan other things in the house).
Alin
-- -- Alin Dobra, Gainesville, Florida
Douglas Bordner
3315 posts in 815 days
622 days ago
I’ve used oven cleaner, but it does peel the red coating off Freud blades… won’t do that again.
View Robert Smith's profile
Robert Smith
95 posts in 672 days
563 days ago
I SPRAY MINE WITH WD40
-- Robert, mountainwoodcarving@netzero.net
View CutNRun's profile
CutNRun
111 posts in 597 days
563 days ago
I’ve used the “orange or citrus version” of Pinesol. It was on sale at Safeway so I figured why not give it a try – the price was right. I found a shallow round pan, poured in some Pinesol and then put the saw blade in for a soak. With a light brushing it came out looking like new. I rinsed off the Pinesol, dried the blade and then used WD40 to remove any moisture. Rather than dump out the used Pinesol, I just used a funnel and put it back in the bottle.
-- CutNRun - So much wood, so many trails, so little time
View douglbe's profile
douglbe
128 posts in 712 days
563 days ago
I too use Simple Green with a brass bristle brush, cheap and works very well.
-- Doug, Cass City, Michigan
View TomK 's profile
TomK
495 posts in 625 days
563 days ago
Orange Oil, fulll strength. Soak for 10 minutes and brush. Wear eye protection, this stuff is potent!
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
View Pathpounder's profile
Pathpounder
48 posts in 644 days
562 days ago
I used Simple Green on two of my blades last night. Set them in a pizza pan, sprayed on a little green, let it set a few minutes then brushed off with a brass brush. They look great but I have not cut with one yet.
-- http://ragtimewoodwork.blogspot.com/
View rikkor's profile
rikkor
11345 posts in 625 days
562 days ago
WD-40 works pretty good.
View Joey's profile
Joey
255 posts in 566 days
562 days ago
Home depot sells some stuff called krud kutter, it’s in the paint section. i clean both my router bits and saw blades with. It’s cheap and works great.
-- Joey, Magee, Ms http://woodnwaresms.com
View GaryK's profile
GaryK
9429 posts in 739 days
562 days ago
I keep a 5 gallon paint bucket on hand for cleaning my 10” blades. They fit perfect in the bottom.
For a cleaning solution, like others I use simple green and a brass brush after soaking overnight.
Just 1/4 to 1/2” in the bottom is all it takes. Then I empty it into a jar to use again.
Looks as good as new and is very cheap.
Gary
Bookmark And Share This Page
