Would cutting copper damage hand saw teeth?
Forum topic by ShawnSpencer posted 09-16-2015 04:00 PM 1799 views 0 times favorited 21 replies Add to Favorites Watch
View ShawnSpencer's profile
ShawnSpencer
81 posts in 1508 days
09-16-2015 04:00 PM
Topic tags/keywords: question blade
I am planning to use copper rods to dowel some joints. Would the copper damage the teeth of my flush trim saw or power tool blades? I tried some googling but cant find a good answer. Would I be better off finding a junk saw to do this kind of work? Thanks in advance guys.
-- I know you know...
21 replies so far
View jmartel's profile (online now)
jmartel
7807 posts in 2117 days
#1 posted 09-16-2015 04:07 PM
It will probably dull your blades easier, but copper is softer than brass. Brass is cut by woodworking machinery fairly easily. If you have a dremel tool, that’s probably best. Then flush it up with a sander after you are done.
View WoodNSawdust's profile
WoodNSawdust
1417 posts in 1143 days
#2 posted 09-16-2015 04:07 PM
Copper is harder than most people think. I would not risk one of my good saws by trying to cut it. Could you pre-cut the rod to length, finish the end, and then drive it into the joint?
View jdh122's profile
jdh122
995 posts in 2784 days
#3 posted 09-16-2015 04:07 PM
Why not use a hacksaw? You could rub it on a sharpening stone on one side to remove the set.
-- Jeremy, in the Acadian forests
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1541 days
#4 posted 09-16-2015 04:36 PM
Hack saw,dremel,metal cutting blade,Cutting blade in a 4.5” angle grinder.
View MrRon's profile
MrRon
4718 posts in 3210 days
#5 posted 09-16-2015 04:37 PM
Why copper? I never heard of it being used for dowels. If it has to me metal, aluminum would be a better choice; cheaper and cut with woodworking machines.
daddywoofdawg
#6 posted 09-16-2015 04:38 PM
I think it’s the look.
View SenecaWoodArt's profile
SenecaWoodArt
433 posts in 1586 days
#7 posted 09-16-2015 05:00 PM
Some times, there may not be enough information to access the problem and this may be one of those cases. IN NO CASE would I EVER use my wood cutting tools on ANY kind of METAL. A hacksaw was design to cut metal and they are not very expensive. Every good shop should have one as they provide solutions to many common house hold problems.
-- Bob
ShawnSpencer
#8 posted 09-16-2015 05:02 PM
It will probably dull your blades easier, but copper is softer than brass. Brass is cut by woodworking machinery fairly easily. If you have a dremel tool, that s probably best. Then flush it up with a sander after you are done.
- jmartel
This is what I was thinking of doing. The copper is just for the look. Trying some new things. I had seen Kyle Toth cut copper sheets on his table saw but, my first impression was that is bad for your blade. Thanks for the input guys.
View gfadvm's profile
gfadvm
14940 posts in 2657 days
#9 posted 09-17-2015 12:01 AM
Copper can be pretty hard if not annealed but the biggest issue is round stock will want to spin and get out of your control in a nanosecond! Use a hacksaw or cutoff wheel.
View waho6o9's profile
waho6o9
8165 posts in 2543 days
#10 posted 09-17-2015 01:31 AM
Hello hacksaw
TopamaxSurvivor
18248 posts in 3642 days
#11 posted 09-17-2015 01:45 AM
Copper alloys vary in hardness. I have cut aluminum with my table saw. I do not use one of my premium, spendy blades ;-)
View Woodknack's profile
Woodknack
11482 posts in 2347 days
#12 posted 09-17-2015 05:53 AM
I’ve used 1/4” copper rod as pins in woodworking joints, cutting them was no issue at all. Steel is much harder than copper. There are tropical hardwoods that are harder than copper, harder than brass even. One tip, it’s best to flush cut them as close as possible because when you sand, the wood will wear away faster and the copper wants to stand proud by just enough that you can feel it. I kept switching between a file and sandpaper to keep the copper perfectly flush.
TopamaxSurvivor
#13 posted 09-17-2015 06:01 AM
I ve used 1/4” copper rod as pins in woodworking joints, cutting them was no issue at all. Steel is much harder than copper. There are tropical hardwoods that are harder than copper, harder than brass even. One tip, it s best to flush cut them as close as possible because when you sand, the wood will wear away faster and the copper wants to stand proud by just enough that you can feel it. I kept switching between a file and sandpaper to keep the copper perfectly flush.
- Rick M.
Have you tried using a short pin and sanding down to it? If so, how did that work?
View LeslieJohn's profile
LeslieJohn
15 posts in 1361 days
#14 posted 09-17-2015 08:26 AM
ShawnSpencer
#15 posted 09-17-2015 12:30 PM
- TopamaxSurvivor
That is a great idea, I also thought of leaving the rods a touch proud and hammering them to kinda mushroom the tops.
