grain orientation for splines
« back to Joinery forum
Forum topic by JeffP posted 09-16-2015 02:15 PM 760 views 0 times favorited 4 replies Add to Favorites Watch
View JeffP's profile
JeffP
573 posts in 1357 days
09-16-2015 02:15 PM
Topic tags/keywords: joining question
I have seen a few videos where they are using splines to either dress up or strengthen the joints.
When it’s done tastefully, I rather like the look of it, so I’m planning to try it out myself soon.
One thing that I haven’t quite figured out is the best orientation of the grain in the spline pieces.
If you make the splines such that the grain of it is in line with one side or the other of the “box”, then one of the two sides will have end-grain visible. (the end grain of the small spline piece)
One could orient the spline at 45 degrees to both faces and then you would have end-grain on both faces, which would at least be symmetrical. In addition to symmetry, it seems this would also put the strongest dimension of the spline “across” the joint, which my gut tells me would be the strongest orientation.
Is there a commonly accepted “best way” to do this?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
View Kazooman's profile
Kazooman
998 posts in 1917 days
#1 posted 09-16-2015 02:25 PM
Yes, the second way you described.
View Yonak's profile
Yonak
986 posts in 1486 days
#2 posted 09-17-2015 04:44 AM
If you want to get fancy you could glue up a block with an outside skin (as thick as you need to be able to trim it flush) creating a grain orientation which is the same as the two sides of your case and cut it into splines.
View tomd's profile
tomd
2148 posts in 3735 days
#3 posted 09-17-2015 04:54 AM
45 degree, gives strength and keeps color of spline the same on both sides.
-- Tom D
View AlaskaGuy's profile
AlaskaGuy
4045 posts in 2274 days
#4 posted 09-17-2015 05:02 PM
deleted
