Dust Collection for Delta JT160 (same as Porter Cable PC160JT)
Forum topic by aussiechippie posted 11-19-2009 06:56 PM 9028 views 0 times favorited 5 replies Add to Favorites Watch
View aussiechippie's profile
aussiechippie
27 posts in 3378 days
11-19-2009 06:56 PM
I was lucky enough to be given a brand new Delta JT160 for my new shop. I am currently using a Ridgid Wet/Dry vac for dust collection and would like to know what advice people can give for how to collect shavings from the dust chute on the side of the jointer. I can’t find any accessories designed specifically for this task and wonder what others do in this situation.
Look forward to your responses! You guys are awesome!
-- If at first you don't succeed... then skydiving's not for you...
5 replies so far
View iamwelty's profile
iamwelty
259 posts in 3318 days
#1 posted 12-01-2009 03:04 PM
Me too… There’s got to be something out there… I’ll holler if I find anything
-- There is a fine line between eroticism and nausea...
iamwelty
#2 posted 12-02-2009 04:34 AM
Not really what I was looking for but here’s something…
http://lumberjocks.com/projects/16007
View cstrang's profile
cstrang
1832 posts in 3370 days
#3 posted 12-02-2009 03:40 PM
You may want to try Lee Valley or Rockler for a aftermarket dust hood that will fit, may not be designed specifically for this jointer but it may work. If that option is exhausted you could go to a local sheet metal place, make a rough sketch with some dimensions and they should be able to fab something up for you. Hope this helps and good luck!
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
View Berg's profile
Berg
116 posts in 3392 days
#4 posted 12-02-2009 04:18 PM
The $5 solution.
I use a 6” universal square flange (Google: 6” UNIVERSAL FLANGE) that I clamp on the jointer with two speed clamps. Some day I’ll bolt one on… maybe.
-- Pete - "To every thing there is a season Turn! Turn! turn!" [Ecclesiastes and Pete Seeger]
View Berg's profile
Berg
#5 posted 12-03-2009 04:24 AM
Here are a couple pics of my jointer with the flange
The flange
With the hose attached
6” flange for a 4” dust collector hose. Held in place with two clamps. The suction from the dust collector keeps most (all?) the chips from sneaking out the ares not covered. Works for me ($5 solution). The duct tape adds a little to the diameter and helps keep the hose on. I don’t tape the hose to the flange.
