Melamine Kitchen Cabinets
Forum topic by CMS2 posted 09-16-2015 01:51 AM 947 views 0 times favorited 10 replies Add to Favorites Watch
View CMS2's profile
CMS2
5 posts in 1068 days
09-16-2015 01:51 AM
I’m going to build new kitchen cabinets from 3/4 melamine. The backs of the cabinets will also be 3/4 melamine. Can I hang the upper cabinets by screwing through the melamine into the studs or will I need some type of “backer” piece
10 replies so far
View Pezking7p's profile
Pezking7p
3217 posts in 1735 days
#1 posted 09-16-2015 01:57 AM
If the backs are 3/4, screw away.
-- -Dan
View ChefHDAN's profile
ChefHDAN
1097 posts in 2933 days
#2 posted 09-16-2015 08:47 PM
Is that going to be particle board 3/4” melamine?
If so they’ll be goofy heavy, might consider building the cabinet with the back 3/4” into the case so that you could have a French cleat to hang them
View Bmezz's profile
Bmezz
44 posts in 1467 days
#3 posted 09-16-2015 08:53 PM
5/8” is standard including the back. If you rabbet or dadoe the back then you have no worries screwing through the back. 35 years in the kitchen business and never lost a cabinet. Cheers, Bob
-- Member Valley Woodturners Ottawa. Member AAW
View CMS2's profile
CMS2
#4 posted 09-16-2015 11:24 PM
Thanks for the replies. Any suggestions for the best screws to use when hanging them?
View timbertailor's profile
timbertailor
1594 posts in 1508 days
#5 posted 09-17-2015 12:30 AM
Melamine is not a board, but a material used to veneer wood or in most cases, particle board. Particle board and MDF do not take screws well. I suggest a French Cleat design that ChefHDAN suggested.
View jerryminer's profile
jerryminer
937 posts in 1525 days
#6 posted 09-17-2015 05:07 AM
Particle board and MDF do not take screws well. – timbertailor
Yes, but he’s screwing through the PB into wall studs, which hold screws fine. These cabinets will be heavy, but you can screw through the back at will.
(Installing a French cleat would mean screwing into the PB—-an admittedly weak connection—or trying to glue to the melamine—-also problematic. Better to screw through the PB and into the studs.)
“Best screws”? Something like this:
Quick Screws
Bmezz
#7 posted 09-17-2015 10:20 AM
#8 or #10 at 2 1/2” or 3” depending on wall construction. Always use cup washers. They’ll never move.
View AlaskaGuy's profile
AlaskaGuy
4272 posts in 2393 days
#8 posted 09-17-2015 10:29 AM
I have build a lot of cabinets using Melamine (over particle board). My standard back is 3/4”. Absloulty no need for a French cleat system. Screw through the 3/4 back in a stud will be sufficient.
Most all my cabinets no matter what the material has a 3/4 back. The box is constructed like in the picture. the top and deck of the cabinet are 3/4 less in width than the sides. I screw (confirmats) through the sides into the back and though the back into the top and deck. Been doing this way for a long time. It works.
View kKirk's profile
kKirk
8 posts in 1312 days
#9 posted 09-17-2015 03:27 PM
I’ve done the 3/4” melamine (particle board) backed upper cabinets. As a side note I did 1/4” melamine backs on the lowers since you aren’t ‘hanging’ the cabinets off of the wall. I used FastCap cabinet installation screws available at Menards. They are specifically made for this installation with an extra large flat head as to not blow through the particle board. Then they have melamine adhesive cover dots that match the size of the screw heads and match the melamine color you have chosen.
ChefHDAN
#10 posted 09-17-2015 03:48 PM
Agreed all 3/4” melamine PB into a stud is plenty, my cleat suggestion was because they can get so damn heavy, it’s nice to be able to level the cleats on the wall and then throw the cabinets up onto the wall. Could do the same thing with a level 2”x4” cleat at the level base line of the cabinets and have a helper or a deadman to hold them in place while you drive the screws home
