« back to Woodturning forum
09-15-2015 11:47 PM
well I have a 70-100 rikon mini lathe and I turned a large bowl on it,,well it was just 7 1/2 inches but that’s about all I could turn on it,,but I tried turning another one,,,and I got a lot of vibration so I slowed the speed down,,and when I got it round I turned the speed up a little and still had the vibration plus it looked like I was actually slowing the lathe down as I was cutting on it,,and I kept sharping my tools,,actually I believe I could have stop it if I had pushed much harder,,i didn’t know maybe if the shaft was bent or maybe I need a new belt,,,could anyone help me to sole this problem,,so far it has been a good lathe and I hate to trash it,,thank you
#1 posted 09-16-2015 12:36 AM
Make sure your motor is adjusted to tighten the belt. If that is ok the belt could be bad.
#2 posted 09-16-2015 01:51 AM
You didn’t say how the bowl is mounted to the lathe. Is there a chance it’s loose at the mount, maybe the chuck is turning but the bowl is slipping in the jaws? Look close to see if everything turns at the same rate.
-- My reality check bounced...
#3 posted 09-16-2015 01:57 AM
I started out using a face plate till I got a tenon cut on the other end,,but you are right I check the face plate and it was still tight,,but after putting it on the chuck,,it still acted the same way,,,
#4 posted 09-16-2015 05:34 AM
Vibration is normal on bowls until they are balanced. Slowing down is normal on lathes with smaller motors. And green wood can go out of round almost while you are turning, pause for a second and when you start again it’s out of round. So can’t be sure there is anything wrong with it, might all be normal happenings.
#5 posted 09-16-2015 12:14 PM
this is the first bowl I turned,,about 7 1/2 inches,,,
#6 posted 09-16-2015 12:26 PM
I agree with Rick M. ... it may be fine. I have a small lathe with a 1/2 hp motor, and it really doesn’t like to be pushed to its limits, especially if I’m turning dense stock. Try mounting and turning a smaller piece of stock. If your vibration problem goes away, at least you’ll know nothing is bent.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12029 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2108 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4904 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6695 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28058 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
212 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5410 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1419 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6232 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1388 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2154 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1187 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4756 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2200 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8845 |
