Pizza paddle design help
Forum topic by bues0022 posted 11-19-2009 07:01 AM 2134 views 0 times favorited 12 replies Add to Favorites Watch
View bues0022's profile
bues0022
245 posts in 3066 days
11-19-2009 07:01 AM
Topic tags/keywords: question
I’m planning on making a few pizza paddles for my wife for Christmas. I have an idea on the design, and since I’ve never made multi-species projects (cutting boards etc.) I wanted to get some expert opinions. Here’s what I’ve come up with so far:
pizza paddle design
woods:
light – hard maple
dark – Walnut
red – ???
I want a really vibrant red, but one that won’t fade (as I’ve heard that Paduk might?) Will mahogany have enough red, or is it going to blend a little too closely with the walnut? I’d like to not have to spend a ton on a wood like bloodwood, ideas?
What about the multiple “wedges”? should I try to make the bottom edge more closely a similar width?
How do you all think the color combinations flow?
I’d appreciate any feedback you might have, good or bad.
-- Ryan -- Bristow, VA
12 replies so far
116906 posts in 3483 days
#1 posted 11-19-2009 08:42 AM
I think it looks great but how will it hold up to heat?
bues0022
#2 posted 11-19-2009 04:50 PM
To be honest I hadn’t really given the heat issue much thought. It should handle just fine, won’t it? My parents have a few of them that they’ve had for years and years, and they aren’t heat damaged at all. You have it in the oven just long enough to get the pizza out.
View closetguy's profile
closetguy
744 posts in 3798 days
#3 posted 11-19-2009 08:14 PM
Padauk will turn dark and loose it’s reddish orange color eventually. Bloodwood is your best choice for a longer lasting red. You may want to try walnut, cherry, jotaba, with maple trim. I like this combination.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View knotscott's profile
knotscott
7873 posts in 3281 days
#4 posted 11-19-2009 09:02 PM
Padauk is pretty neat stuff, and contrasts nicely with maple, but….many exotics woods have some toxicity to them, so you’ll want to inquire and check out how to deal with it first.
bues0022
#5 posted 11-19-2009 09:26 PM
I picked up a piece of Jatoba this morning for the reddish wood. I was able to find a piece that was much more of a red color. We’ll see how it holds up! Now I gotta get back home and start working!
View jlsmith5963's profile
jlsmith5963
297 posts in 3254 days
#6 posted 11-20-2009 12:07 AM
bues0022
The pizza will expose the paddle to more heat sitting on top of it than the time spent in the oven. Now isthat is a problem? For domestic use, I doubt it.
-- criticism: the art of analyzing and evaluating the quality of an artistic work...
jlsmith5963
#7 posted 11-20-2009 12:10 AM
Oh and as to the design, I would soften the hard angles, if you just think about it, how many utensils in the kitchen have sharp edges (that aren’t meant to cut)? I believe there is a reason for that.
bues0022
#8 posted 11-20-2009 12:49 AM
I was thinking the same on the heat. Yeah, the pizza is hot when it comes out – but not that hot for that long. It’s kinda the same idea as putting it on a cutting board, right?
I’m also planning on giving everything a fillet on all edges, I just didn’t take the time to draw it in. Thanks for the reminder.
View Jonathan's profile
Jonathan
2608 posts in 2956 days
#9 posted 02-24-2011 04:27 AM
Did this project ever come to fruition? I didn’t see it listed in your Projects. I’m asking because I’m also done with a pizza peel that is also a multi-species lamination.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
bues0022
#10 posted 02-24-2011 07:59 PM
No, unfortunately it never did go anywhere. It’s been “back-burnered” for some time now. I actually have all of the materials, but since this idea started I finished grad school, moved, got a new job, and with our first child on the way I’m putting all efforts into a maloof-style rocker. Thanks for reminding me that I eventually need to build this thing.
Jonathan
#11 posted 02-25-2011 02:19 AM
You’ve been a busy guy, and will continue to be, from the sounds of it.
Ahh, a Maloof-inspired rocker… on my list for either later this year, or sometime next year. Have fun with the build. Which plans are you using, if you don’t mind me asking? I haven’t decided which plans I’m going to use yet, and have actually considered buying several different plans and building them all, over time, of course.
Here’s a link to a question I posed about applying a finish to a pizza peel that I’m almost finished with, including a couple of mediocre pictures to inspire you to build yours sometime in the next year or two:
http://lumberjocks.com/topics/24776
bues0022
#12 posted 02-25-2011 10:34 PM
I saw your post about the finish on yours, but honestly I didn’t keep up on it much. I’ll keep it in mind for when I’m finally done with my rocker. I’m using the Hal Taylor plans, but have modified them a bit to suite my ideas. Check out my blog, and good luck when you start!
