Hold-down for TS Sled
Forum topic by AtlasRook posted 09-15-2015 01:48 PM 1230 views 0 times favorited 8 replies Add to Favorites Watch
View AtlasRook's profile
AtlasRook
25 posts in 1516 days
09-15-2015 01:48 PM
Topic tags/keywords: tablesaw sled jig question tablesaw
I’m trying to figure out what the best (ie – simplest, cheapest, yet effective) solution is for holding down parts on my tablesaw sled. I’ve tried to use scrap blocks to hold down my smaller parts, then clamp that block to the back fence, but it seems like that doesn’t have a lot of hold down force. I’m considering buying some of those hold down / toggle clamps, but it seems inefficient to have to have several mounting holes.
Note: I have a very simple sled: base, back fence, and front fence. No fancy t-tracks anywhere.
Any suggestions?
8 replies so far
View Ghidrah's profile
Ghidrah
667 posts in 1216 days
#1 posted 09-15-2015 01:57 PM
Some people with said issue also use sandpaper, DS tape or spray glue it to the sled, grips pretty good. Using a stop and downward finger pressure has worked well for me.
-- I meant to do that!
View SirIrb's profile
SirIrb
1239 posts in 1224 days
#2 posted 09-15-2015 02:47 PM
this guy. But I have no problems holding with finger strength.
http://www.mscdirect.com/product/details/62242979?src=pla&cid=PLA-Google-PLA+-+Test&CS_003=7867724&CS_010=62242979
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2103 days
#3 posted 09-15-2015 03:31 PM
I use my fingers, but I also don’t apply finish to the bare wood and MDF surfaces inside my sleds. People who make inside surfaces slippery are creating another problem to solve.
Remember, the blade is pushing the work back at you and down.
View BurlyBob's profile
BurlyBob
5487 posts in 2259 days
#4 posted 09-15-2015 03:37 PM
I’ve got 1000 grit PSA sand paper on the face of my miter gauge to keep wood from slipping. I’ve used it in other similar applications. It holds the wood in place and does not mar the finish.
View gfadvm's profile
gfadvm
14940 posts in 2683 days
#5 posted 09-17-2015 12:27 AM
Go to Eagle Lakes Woodworking’s site and look at their “Super Sled” build plans. I built this sled years ago and their hold downs are no cost, very effective, and SAFELY hold really short pieces with no fingers involved!
View Jim Finn's profile
Jim Finn
2656 posts in 2915 days
#6 posted 09-17-2015 01:36 AM
This is what I made to use as hold downs on this taper jig.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Heisinberg's profile
Heisinberg
40 posts in 1593 days
#7 posted 10-04-2015 04:12 PM
Here is my TS sled I made earlier this year. http://lumberjocks.com/projects/126305 used some T track on the fence and made a stop block/hold down for it. I also have a disposable version that I don’t mind running through the blade. It can hold very small piece and keeps you finger tips where they belong. If you have any questions as to how the hold down works I can take a few picks and post if you like.
-- "I've still got things left to do." – Walter White
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3280 days
#8 posted 10-06-2015 08:42 PM
I just got some of these to use in t-track on all my sleds.
http://www.rockler.com/toggle-clamp-mounting-plate
There are many other hold down clamps that work in t-track, or make your own.
You can use store bought t-tract, or with a router and a t-slot bit, add your own.
http://www.rockler.com/rockler-t-slot-cutter-router-bit
-- http://shepherdtoolandsupply.com/
