Drilling holes in glass
« back to Coffee Lounge forum
Forum topic by DetDad posted 11-18-2009 11:24 PM 1731 views 0 times favorited 7 replies Add to Favorites Watch
View DetDad's profile
DetDad
8 posts in 3498 days
11-18-2009 11:24 PM
Topic tags/keywords: question
I need to drill 1/2 inch holes in wine bottles (empty) for a friend. Anyone have a recommendation as to the drill press speed?
-- Detective Dad, Madison, WI
7 replies so far
View j_olsen's profile
j_olsen
155 posts in 3136 days
#1 posted 11-18-2009 11:47 PM
How to Drill a Hole in Glass…
You’ll use these tips and techniques to drill glass, sea glass, wine bottles, glass block, tile, stone, granite and marble.
Use diamond bits to drill your glass, not carbide bits.
Use diamond hole saws to drill holes 1/4” and larger or to drill holes in thick glass like glass block or wine bottles.
Use plenty of lubrication/coolant to keep your drill tip cool and the hole clean.
Use less pressure! Let your drill bit drill at it’s own pace.
Start diamond hole saws at 600-900 RPM.
Start diamond drill bits at 2500-5000 RPM.
you can see the rest here
-- Jeff - Bell Buckle, TN
View RexMcKinnon's profile
RexMcKinnon
2593 posts in 3159 days
#2 posted 11-19-2009 12:02 AM
That is some precise info Jeff. I can use this also.
-- If all you have is a hammer, everything looks like a nail!
View reggiek's profile
reggiek
2240 posts in 3234 days
#3 posted 11-19-2009 12:08 AM
Cool info….thanks jeff….I haven’t had the need so far….but it will come in handy if I do….
DetDad
#4 posted 11-19-2009 12:40 AM
Thanks Jeff your advice is appreciated
View Rob200's profile
Rob200
313 posts in 3133 days
#5 posted 11-19-2009 09:55 PM
how did the dill ing go I drill win bottles all the time and it is just like jolsenoh said to do I will down load some pix of mine on my page
-- Robert Laddusaw and no I am not smarter then a fifth grader ( and no I canot spell so if it is a problem don't read it ))
View poopiekat's profile
poopiekat
4349 posts in 3699 days
#6 posted 11-20-2009 01:24 AM
I’ve seen holes drilled in bottles using a sandblaster, with a fat chunk of steel with a hole in it used as a template. Silicon carbide media was used. Never actually seen the process though, just the end result.
View GMman's profile
GMman
3902 posts in 3662 days
#7 posted 11-20-2009 01:32 AM
j-olsen-oh has the answer and that is the only way to drilled a hole in a bottle.
The quesion was drilling.
