Satin to matte finish
Forum topic by BalsaWood posted 09-14-2015 10:58 PM 743 views 0 times favorited 4 replies Add to Favorites Watch
View BalsaWood's profile
BalsaWood
36 posts in 1062 days
09-14-2015 10:58 PM
I just finished a bookshelf with a few coats of satin Arm R Seal. I’d like to dull it down a little bit and give it less sheen. What would be the best way to do this?
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1006 posts in 969 days
#1 posted 09-14-2015 11:03 PM
0000 Steel Wool or white synthetic pad, wipe it down with some mineral spirits and then wax
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2273 days
#2 posted 09-30-2015 04:15 PM
I usually rub Arm-R-Seal out w/ 0000 steel wool, which I rub in some Johnson’s paste wax before using. You can buff to your desired sheen. I like satin, but I still do the wax because I think it give it a much nicer tactile feel.
View DrDirt's profile
DrDirt
4421 posts in 3645 days
#3 posted 09-30-2015 04:27 PM
Ditto to Turtle and Ed – - steel wool and wax.
View jmartel's profile
jmartel
7687 posts in 2053 days
#4 posted 09-30-2015 04:31 PM
You could also pour some arm r seal into a container with a lid and let it sit for a couple days. Pour off the clear liquid off the top and the cloudy liquid left is matte Arm R Seal. The clear is basically gloss.
