cabinet plans
Forum topic by BrantlyJ posted 11-18-2009 06:06 PM 974 views 0 times favorited 8 replies Add to Favorites Watch
View BrantlyJ's profile
BrantlyJ
5 posts in 3140 days
11-18-2009 06:06 PM
Hi there. I’m attempting to make some cabinets for my closet. I was wondering if someone might take a look at the drawing I made up and let me know if I’m on the right track.
This drawing is for a 3 drawer cabinet that will be on the floor. It will be made out of 3/4” oak ply with solid oak facing.
I do know the bottom dado is in the wrong position. I also know the facing dimentions might be incorrect, I also haven’t figured out the deminsions for the drawers so I havn’t included those yet.
I’m doing a 3/8” x 3/8” rabbet to secure the top. I will rabbet both the top and sides for increased strength.
Also the only tools I have to work with will be a router table, circular saw w/ 8’ cutting guide and a cheap craftsman table saw and a biscuit jointer….
here’s the drawing. http://www.flickr.com/photos/12661965@N05/4114504591/
thanks for looking
8 replies so far
View GFYS's profile
GFYS
711 posts in 3500 days
#1 posted 11-18-2009 06:47 PM
Needs some work Brantly
The back is is flush with the top and will show the edge.
I didn’t see a toe or any parts for bottom supports.
Several dimensions are wrong.
I’m not sure why you would go to the expense to use 1/4” oak plywood for the back but use mdf for the bottom unless you have these materials at hand already.
I am assuming you are doing mortice and tenon joints of some type on the styles and rails. Difficult with the tools you have.
117128 posts in 3606 days
#2 posted 11-18-2009 06:55 PM
I was going to bring what Dan did about the face frame it looks like you Mortice an tenoning it. For a first project using pocket screws are much easier. You can pick up a single hole kreg pocket hole jig and drill bit set for around $20.00
BrantlyJ
#3 posted 11-18-2009 07:13 PM
ok, some explination… the oak ply on the back is because I will have plenty left over from the cabinet that has doors. I want the nice back in that cabinet. The MDF on the bottom, because there wasn’t enough oak ply. I did put in a toe kick, but didn’t put in the dimension it will be 3”high, 3” deep.
as for the face frame, I bought a biscuit jointer to attach it to the main frame. I figured I would also use it to make the face frame… If there is a better way I’m open to suggestions.
View GFYS's profile
GFYS
#4 posted 11-18-2009 07:27 PM
biscuits will work. do you have a biscuit jointer for FF size biscuits?
in any event you will find out that to make face fronts the styles and rails need to be the same thickness. Without a planer or thickness sander this just isnt very easy.
BrantlyJ
#5 posted 11-18-2009 07:45 PM
no, just 0, 10, 20
View GFYS's profile
GFYS
#6 posted 11-18-2009 07:51 PM
That means your rails will need to be wide enough to recieve your biscuits.
View GFYS's profile
GFYS
#7 posted 11-18-2009 07:58 PM
...although…I have used a router with the proper size slotter to use FF size biscuits.
BrantlyJ
#8 posted 11-18-2009 08:29 PM
hmm, ever used the Kreg pocket hole jig to attach the face frame? If that would work I might do that instead….
