Can I Laminate Pressure Treated Plywood?
Forum topic by Tony1212 posted 09-14-2015 04:52 PM 712 views 0 times favorited 1 reply Add to Favorites Watch
View Tony1212's profile
170 posts in 1666 days
09-14-2015 04:52 PM
Topic tags/keywords: pressure treated plywood
For permit reasons, the company that built my garage about 8 years ago had to use 1/2” pressure treated plywood as sheathing. They left a bunch of scraps behind for me to use.
I’ve since been using it as shelves on my old workbench which I recently took apart while redoing my shop. Now I want to use it to make the Woodsmith Shop Roll Around Shop Stool (PDF of plans).
It requires that the sides and rails be made of laminated 1/2” ply. Will gluing up the PT ply last? Or is there an issue with the chemical used for treating plywood that would affect the bonding of the glue?
-- Tony, SW Chicago Suburbs
1 reply so far
View JoeinGa's profile
7733 posts in 1939 days
#1 posted 09-14-2015 05:11 PM
I’ve glued up PT ply before and it held fine.
