Dowel Joinery
« back to Joinery forum
Forum topic by borny posted 09-14-2015 09:19 AM 870 views 0 times favorited 11 replies Add to Favorites Watch
View borny's profile
borny
26 posts in 2200 days
09-14-2015 09:19 AM
Quick question.. Is there any reason why I couldn’t use dowel joinery in case construction, like the Krenov style cabinet, in a larger piece of furniture, like a dresser? Dimensions 31×18 x 34” (forgive me if the dimensions are labeled wrong!!) I’m inclined to say it is strong enough, especially after the back has been attached, but I haven’t seen anyone who has done this online. I know dove tails are the traditional joint, but I’m a little pressed for time.
TIA,
Dan
11 replies so far
View CB_Cohick's profile
CB_Cohick
487 posts in 1428 days
#1 posted 09-14-2015 03:21 PM
Glue and dowels are a good joint, much stronger than either pocket holes or a butt joint. Unless your case is going to be subjected to a lot of stress it should hold up I would think.
-- Chris - Would work, but I'm too busy reading about woodwork.
16278 posts in 4395 days
#2 posted 09-14-2015 03:44 PM
No problem. I have used dowel joints in both tables and casework.
borny
#3 posted 09-14-2015 08:22 PM
I figured it would be fine, i just haven’t seen anyone online building a case like this. I am going to glue the sides into the top. Grain direction isn’t the issue, i was worried the dowels would only penetrate 1/2” into the top. I did a test with some scraps and was pretty amazed on how strong the joint is with only a couple fields and I will be using more over the 18” length of the joint. Plus I don’t think dressers go through a tremendous amount if stress.
Here is a picture of the joint I’m making. The top will over hang the sides 3/8”.
borny
#4 posted 09-14-2015 08:26 PM
Try paying a picture again..
View MT_Stringer's profile
MT_Stringer
3183 posts in 3408 days
#5 posted 09-14-2015 08:35 PM
I can’t figure out which end is up!
View AlaskaGuy's profile
AlaskaGuy
4651 posts in 2486 days
#6 posted 09-14-2015 08:36 PM
Dowel joints are use extensively in European flame-less cabinets.
borny
#7 posted 09-14-2015 08:47 PM
For the most part the top and bottom are the same. Not sure how to rotate the picture. Lol
Do youu think as hobbyists we have a tendency to “over build” furniture, because we are worried about quality? I really like dowel joinery, but feel sometimes it’s too simple!
AlaskaGuy
#8 posted 09-14-2015 08:48 PM
borny
#9 posted 09-14-2015 08:55 PM
Now I’m curious why my phone rotated the picture..
AlaskaGuy
#10 posted 09-15-2015 05:42 AM
Now I m curious why my phone rotated the picture..
- borny
Because you haven’t read this thread.
http://lumberjocks.com/topics/117186
borny
#11 posted 09-15-2015 05:56 AM
Thanks!! Knowing is half the battle!!
