Looking for a past project - can you help?
Forum topic by Randy Sharp posted 11-17-2009 09:36 PM 963 views 1 time favorited 7 replies Add to Favorites Watch
View Randy Sharp's profile
Randy Sharp
363 posts in 3577 days
11-17-2009 09:36 PM
A couple of months ago, someone posted a nifty project regarding the use of a Forstner bit to produce a “ball in a box” from a single piece of wood. If I recall, the post also had links to a fellow (youtube) who creates several “remarkable” wooden puzzles.
I’ve looked and looked, but can’t find the post. Wish I had marked it on my favorites.
Can someone help me locate the post?
Thanks!
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
7 replies so far
16272 posts in 4122 days
#1 posted 11-17-2009 10:24 PM
I’m not ignoring you, Buddy….I can’t find it either. Maybe it was a joint hallucination. :-)
View PurpLev's profile
PurpLev
8534 posts in 3553 days
#2 posted 11-17-2009 10:25 PM
I’m here for the ride too, never seen it. but curious as hell now.
Randy Sharp
#3 posted 11-17-2009 10:30 PM
I don’t even know the correct name of the project, or I’d google it. You forstner into six sides of a block of wood, until a loose center piece is left to tumble around.
Randy Sharp
#4 posted 11-17-2009 10:45 PM
I work with Sawdustonmyshoulders. He found it – http://www.youtube.com/watch?v=TfV_APBk16Q. It’s called a “Cube in a cube.”
View papadan's profile
papadan
3584 posts in 3272 days
#5 posted 11-18-2009 02:01 AM
If I may offer a suggestion, use 2 Forstner bits. Grind the starter tip off the second one. Start your holes as normal but stop at about 1/8” into the block. After starting all sides, change bits and finish all the holes. This will give a smooth inside block without the starter point marks in it.
116902 posts in 3481 days
#6 posted 11-18-2009 02:10 AM
Here’s one link I do know it it’s the one your looking for?
http://noolmusic.com/utube_live/making_a_wooden_ball_without_a_lathe.php
View KnotWright's profile
KnotWright
258 posts in 3392 days
#7 posted 11-18-2009 02:28 AM
I think this is one of the projects you are looking for:
http://lumberjocks.com/projects/21236
-- James
