Table saw power
Forum topic by Mrowell posted 09-13-2015 04:35 PM 694 views 0 times favorited 8 replies Add to Favorites Watch
View Mrowell's profile
Mrowell
112 posts in 1106 days
09-13-2015 04:35 PM
Topic tags/keywords: table saw workshop electrical 240v 220v question tablesaw
I am looking into a couple different table saws (Grizzly G0691, Grizzly 1023rlwx) and noticed that one says 220V one says 240V?? I was under the impression these voltages are basically the same the 220V just reflects the power loss while the 240V reflects what the main feed is?
If I have 240V outlets can I run a 220V machine on it without damaging the machine?
Thanks and look forward to responses!
-- Matt R
8 replies so far
View bigblockyeti's profile
bigblockyeti
5095 posts in 1687 days
#1 posted 09-13-2015 04:38 PM
Yes, you can. Quality control on the written information coming with some of these machines is non-existent.
View TheFridge's profile
TheFridge
9249 posts in 1453 days
#2 posted 09-13-2015 04:39 PM
Yep. Same thing.
Mrowell
#3 posted 09-13-2015 04:52 PM
Okay Great so I am not going crazy!!
Thanks guys
-- Matt R
TheFridge
#4 posted 09-13-2015 05:58 PM
Nope. 220,240,250 all the same.
View jonah's profile
jonah
1659 posts in 3265 days
#5 posted 09-13-2015 06:24 PM
220V is an older way to describe 240V. Depending on the equipment, it may say 250V because that’s the maximum nominal voltage the tool can accept. Most residential service is 120VAC per pole, or 240V for the two pole service.
MrUnix
6593 posts in 2166 days
#6 posted 09-13-2015 06:29 PM
And to further obfuscate things… those motors are 3600 rpm even though the nameplate says 3450 :)
Mrowell
#7 posted 09-14-2015 02:00 AM
Awesome thanks for all the feedback!
-- Matt R
TopamaxSurvivor
18248 posts in 3642 days
#8 posted 09-14-2015 04:07 AM
- MrUnix
Well, only under no load. Under load the rotor never keeps up with the stator; therefore, the slight difference between nameplate and “theoretical” or no load. Nameplate give full load amps, full load rpm, ........ There now, hope that unobfuscates the issue ;-)
