Wipe on stain problem Need help
Forum topic by Michigander posted 09-13-2015 02:23 PM 732 views 0 times favorited 4 replies Add to Favorites Watch
View Michigander's profile
Michigander
220 posts in 2388 days
09-13-2015 02:23 PM
Topic tags/keywords: wipe on stain problem blotchy cherry
I am building a baby bed for my first Grandson. It is made from cherry which is very blotchy so I conditioned it with Charles Neil’s pre stain conditioner. I used General Finishes Gel Stain-Candlewood. I followed instructions to put it on wet and even in excess and then wiped it off with the grain. Everything went well except in one prominent area I missed a spot and didn’t wipe it off before it dried so I have a heavy dark spot that needs to be removed. It has set up over the weekend so I am afraid to try to remove it without some good advice. If I have to, I can sand it back to bare wood and start over, but I was hoping you had some magic formula to blend it in. Your help is very much appreciated. Thanks,
John
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1032 posts in 1035 days
#1 posted 09-13-2015 06:45 PM
Try putting the stain on again a little thicker, let it sit as long as you can to re-wet the area and it might even out the areas when you wipe it off.
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
View ChefHDAN's profile
ChefHDAN
1057 posts in 2819 days
#2 posted 09-13-2015 09:53 PM
I had a similar situation using the exact same stain, I was able to go over it with mineral spirits and rub it out to lighten the coloring, not perfect, but I think I’m the only person that can find the spot…
Michigander
#3 posted 09-14-2015 05:39 PM
Thanks guys for your input. I was away for the weekend so I will try it this afternoon. I appreciate your help.
John
Michigander
#4 posted 09-25-2015 07:22 PM
I used mineral spirits and it did a great job of removing the thick coat of wipe gel stain. Thanks to ChiefHDan for the suggestion!
John
