What's the best wood to use outdoors
Forum topic by cbMerlin posted 11-17-2009 04:10 PM 12392 views 0 times favorited 12 replies Add to Favorites Watch
View cbMerlin's profile
cbMerlin
100 posts in 3448 days
11-17-2009 04:10 PM
I was luckily enough to be driving by a Graters (Ice Cream Shop – with almost a cult like following) as they were discarding several park benches they used for outdoor seating. I got 3 of them. The wood was in pretty bad shape but my wife has mentioned she would like a park bench outside so I figured I could just replace the wood in the frame. The frames are some sort of very heavy metal, almost no rust, did I say very heavy! Two side frames to mount the wood onto and a back insert frame of sorts.
My question is what type wood I should use; hold up the best, look the best, ect. Oh yea, and with the least maintenance. I’ve thought about 5/4 treated board to match my deck but I’m not sure.
Also, I’m only going to be using one of the frames so I have two up for grabs. If anyone in the Pickerington/Columbus Ohio area is interested, I’d love to give them to a fellow LJ. Let me know if you’re interested and I’ll try to get a picture of the frames posted here if you’d like to see them.
-- Sawdust looks better in the garage than cars, explain that to your wife!
12 replies so far
View MedicKen's profile
MedicKen
1615 posts in 3489 days
#1 posted 11-17-2009 04:17 PM
Either Ipe or Teak. Both are very expensive. Another less expensive alternative would be WHITE oak
View Chris Wright's profile
Chris Wright
540 posts in 3508 days
#2 posted 11-17-2009 04:28 PM
You could also go with Trex, that stuff will never warp, splinter, rot or discolor. If you want to go with real wood, then just about any South American hard wood will do. Brazilian Cherry (or Jatoba if you want to be technical) would be good and probably not as expensive as the ones MedicKen mentioned.
-- "At its best, life is completely unpredictable." - Christopher Walken
View neverenoughtools's profile
neverenoughtools
10 posts in 3243 days
#3 posted 11-17-2009 04:48 PM
I used to live in Columbus and do miss Graters. I would be wary of a Trex-type material as the material needs to be supported probably more than the bench will give you. Teak is probably the best choice but at $15-$20 per board foot it is out of reach for many. Ipe is another strong choice but is hard to find, expensive and hard as a rock which makes it very difficult to work. I’ve made many outdoor pieces out of Cypress and have been happy. I live in Cleveland and leave the furniture out during the winter and the Cypress has held up very well. You can find Cypress for less than $2 per board foot at Keim Lumber. Hope this helps.
View rustedknuckles's profile
rustedknuckles
160 posts in 3779 days
#4 posted 11-17-2009 04:54 PM
What about plane old cedar, its light, strong, cheep, extreamly rot resistant and readily available.
-- Dave- New Brunswick
35125 posts in 4428 days
#5 posted 11-17-2009 05:07 PM
I made my benches out of Cypress. The old timers (Colonist) used it for shingles in our area.
View bruc101's profile
bruc101
1200 posts in 3569 days
#6 posted 11-17-2009 06:45 PM
Anything outside I use Cypress…furniture, hand carved signs, outdoor media centers, decorative walls and doors, timber framed pergodas. hot tub surrounds, etc..my home was built in 1974 out of Cypress inside and out…no bugs and no rot.
-- Bruce Free Plans http://plans.sawmillvalley.org
View LesB's profile
LesB
1748 posts in 3470 days
#7 posted 11-17-2009 07:35 PM
I see you are located in the middle of the country and some woods may be hard to get there but my first choice would be Redwood, second Western Red Cedar or Cypress. Another one people don’t think of is Locus which is very rot resistant and should be available in your area. All can be treated with just a deck sealer or linseed oil.
-- Les B, Oregon
bruc101
#8 posted 11-17-2009 10:19 PM
We’ve got lot’s of locust where I live and can’t get any boards. The mills want saw it. Mostly used for rail fences, rustic furniture, stair rails, deck rails and rough cut trusses for smaller open buildings.
I have a friend that owns a rustic furniture shop near me and he gives me his small pieces to use for firewood.
Burns hot, pops and better not fill a wood heater with it because it gets so hot.
Where can you buy the boards?
View LesB's profile
LesB
#9 posted 11-17-2009 10:59 PM
We don’t have much Locus in the Pacific Northwest so no tries to mill it. We do have lots of cedar and Redwood though.
-- Les B, Oregon
View CaptainSkully's profile
CaptainSkully
1601 posts in 3586 days
#10 posted 11-18-2009 06:01 PM
Yeah, Trex flexes too much. Ipe (Brazilian Walnut) isn’t that expensive if you go to a flooring place. Oak will need to be varnished. I like the woods that age gracefully outdoors, like redwood & cypress.
-- You can't control the wind, but you can trim your sails
View bues0022's profile
bues0022
250 posts in 3187 days
#11 posted 11-19-2009 09:35 PM
If you can find Cumaru you could use this also. Very similar in properties to Ipe, but cheaper (at least where I get my wood). I think for 5/4 it was around $6/board foot. More expensive than some domestics, but not terrible. It is extremely hard, and difficult to sand, so make sure your cuts are accurate because you won’t want to sand down even 1/16th of an inch unless you want a good workout!
-- Ryan -- Bristow, VA
117126 posts in 3604 days
#12 posted 11-19-2009 09:45 PM
Ceder,cypress,Redwood, Epi,Teak ,locus,Heat treated southern yellow pine.pressure treated southern yellow pine. The composites like Trex are not structural.
