Sketchup Problem; Punching a hole through a beveled surface?
Forum topic by newTim posted 1308 days ago 3796 views 0 times favorited 12 replies Add to Favorites Watch
View newTim's profile
newTim
529 posts in 1802 days
1308 days ago
Topic tags/keywords: sketchup
So here’s a Sketchup teaser. At least for me. How do I punch a hole through an object with a beveled surface? I want to make a through hole parallel to the back surface. I tried by punching a hole through a rectangle then chopping off the bevel, but it will not ‘cut’ through the hole. I then made the beveled part and placed a hole which went out the back. I then used the rotate tool to align the hole with the back surface but can’t figure out how to chop off the ends.
-- tim hill www.newcalshop.com
12 replies so far
View CaseMan's profile
CaseMan
17 posts in 1321 days
#1 posted 1308 days ago
Right click on the part and select ‘Intersect with Model’. It will create the hole faces as well as the interior tube faces. Just delete the solid faces of the holes that you don’t need.
-- - CaseMan -
View PurpLev's profile
PurpLev
7814 posts in 1844 days
#2 posted 1308 days ago
what CaseMan said- select geometry, and do “Intersect Selected” or “Intersect with Model” then just delete the remaining extra parts that are not needed
View mics_54's profile
mics_54
581 posts in 1667 days
#3 posted 1308 days ago
if they are components you must open them for editing first.
-- Dan, Sterling Alaska, Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
newTim
#4 posted 1308 days ago
Intersect with Model! Now why didn’t I think of that? Can’t wait to get home and give it a try. Many thanks to all.
View Chris 's profile
Chris
1849 posts in 2187 days
#5 posted 1308 days ago
Tim,
let us now how that goes. I’m interested in this topic as well.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
Chris
#6 posted 1308 days ago
Dave you said “don’t forget to correct the face orientation inside the hole” Sorry if i’m being a little dense, but, huh??
newTim
#7 posted 1308 days ago
Thanks Dave. I probably should have stated my original question as; what is the best way to punch a hole through a beveled surface(s)?
Like I said above, I made a circle on the beveled surfavce and used Push/Pull to extend it. Because that surface is on a 15 degree angle the hole went out the back. I then used the Rotate tool the align the hole parallel to the back surface.
Can you think of an easier way?
Todd A. Clippinger
8654 posts in 2295 days
#8 posted 1308 days ago
Dang – Is Dave helping people again?
newTim
#9 posted 1308 days ago
Thanks Dave. So essentially you are drawing a circle in space, pushing it through the piece, then intersecting the tube with the model, then chopping off the overhang?
newTim
#10 posted 1308 days ago
Thanks Dave. You might guess where I’m going with this. I also plan to use it for making pocket holes.
View LesB's profile
LesB
907 posts in 1639 days
#11 posted 1308 days ago
I had to print DaveR’s response on that one because I’m not sure the book I bought on Sketch UP covers this sort of thing. In another 6 months I may have it down. I was going to show some of it to my grand kids during the holidays. They will probably pick it up faster and end up helping me (-;
-- Les B, Oregon
newTim
#12 posted 1308 days ago
Pocket holes… they’re not just for screws anymore. This is what I’m working on.
Just thread a cable and add tension. I’m experimenting with some 1/16” diameter threaded rod I got a Home Depot too. I used mortise and loose tenons on my bed project and thought of this. I’m also adding a loose tenon or two in the middle, but have not put those in the model; yet.
