Spray gun for lacqure
Forum topic by Gixxerjoe04 posted 09-12-2015 05:58 PM 1317 views 0 times favorited 27 replies Add to Favorites Watch
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1542 days
09-12-2015 05:58 PM
I’ve been using a lot of spray lacquer lately, have just been buying the rattle can stuff. Works nice and easy but easy to go through a can quickly and was wondering if it’s beneficial to just buy a spray gun and use that since you can get a lot more stuff when not being bought in a rattle can. Anyone have any recommendations for a a spray gun, something that’s not too expensive but works well? Have never used a spray gun before so not sure what’s good and what’s not.
27 replies so far
View SirIrb's profile
SirIrb
1239 posts in 1195 days
#1 posted 09-12-2015 06:57 PM
Buy a quart cup gun at a pawn shop. I learned to spray on one and knocked out custom cabinetry with one. Should be about $50. This is the one with the pot mounted under the sprayer. All metal. Buy a pneumatic regulator to mount under it so you aren’t trying to blow 100 psi out it and don’t have to regulate at the tank.
View Nubsnstubs's profile
Nubsnstubs
1280 posts in 1695 days
#2 posted 09-12-2015 07:46 PM
You might find a brand new one at Lowe’s for under $50. The sprayers are made in either the Siphon type, or the pressure type. You’d be better off with the Siphon type. You can’t blow it up like the pressure types….... Jerry (in Tucson)
117062 posts in 3542 days
#3 posted 09-13-2015 01:07 AM
I’ve been spraying for 40 years, these spray guns are one of the tools from Harbor freight that are very good for the money.
http://www.harborfreight.com/catalogsearch/result?q=spray+gun
View Tennessee's profile
Tennessee
2860 posts in 2479 days
#4 posted 09-13-2015 12:06 PM
+1 for a1Jim. I have used the 47016 model for a couple of years now.
I buy them when I get a coupon showing them for $9.99. Better and cleaner than any pawn shop unit. And they lay down a pretty smooth layer of lacquer, easy to clean, and if they do break, they are essentially throwaway.
But I still have my original two that I bought two years ago, and they are both still spraying well.
SirIrb
#5 posted 09-13-2015 12:44 PM
Wow, I didn’t know they were so cheap. I saw one in a pawn shop for $45 back in the day. I just figured they would be higher now. Thank God for offshore products and the foreign jobs for youth program (called child labor) (yes I am serious, thank God for them).
I think you talked me in to buying a new quart cup.
Wondering: anyone like gravity fed? Sorry if this is thread jacking but it is on topic.
View MrUnix's profile
MrUnix
6587 posts in 2164 days
#6 posted 09-13-2015 01:08 PM
Wow, I didn t know they were so cheap. [...]Wondering: anyone like gravity fed?
- SirIrb
The one mentioned above (47016) is the purple gravity fed HVLP gun they sell… currently on sale for $15.99, but this months flyer (Sept 2015) has a super coupon for $9.99. I haven’t shot much lacquer through them, mostly oil based enamel – and they lay down a great finish. I also have some quart cup siphon/pressure guns that I used to use a bunch, but ever since I got the purple things, I rarely touch them any more.
Gixxerjoe04
#7 posted 09-13-2015 05:06 PM
For $10, def worth a shot. Any advice on spraying or just general info, what psi does my compressor need to be on? I have a small porter cable compressor.
#8 posted 09-13-2015 05:40 PM
You may have a problem with a small compressor but you can give it a try . Try practicing spraying water on some cardboard to start. Psi will differ according to what your compressor will put out,see how 80psi works with water and then adjust from there.
View Dark_Lightning's profile
Dark_Lightning
3146 posts in 3074 days
#9 posted 09-13-2015 06:10 PM
Be sure to install a line dryer, especially if your compressor is running a lot for the finish work. Water spots under your finish look real bad. The HVLP gun will also consume less air.
-- Random Orbital Nailer
View steve104c's profile
steve104c
18 posts in 1203 days
#10 posted 09-13-2015 06:30 PM
HVLP is the best way to go. One bad thing is that you have to thin it down, and when you thin down lacquer , you lose the gloss the more you thin it. HVLP has less over spray, less product thrown in the air and you won’t need a spray booth. I have and use a HVLP. Keep it clean and you’ll have it for a long. They are a little noisy. I think Wagner now makes a cheap ($) HVLP sprayer and has a good review. steve104c
View AlaskaGuy's profile
AlaskaGuy
4045 posts in 2274 days
#11 posted 09-13-2015 07:05 PM
If you try the HF purple (as I did so far is sprays WB clears as good as my more expensive guns) watch this video.
https://www.youtube.com/watch?v=1PiYhGLlQsU
It’s some modification that will make using the gun a better experience.
View JAAune's profile
JAAune
1788 posts in 2282 days
#12 posted 09-13-2015 07:17 PM
Not all the Harbor Freight guns are equal. Don’t remember the model numbers of the ones that work well.
I prefer gravity feed over siphon feed but a pressure pot if you can find a cheap used one is even nicer and that requires a bottom-feed gun.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2075 days
#13 posted 09-13-2015 07:49 PM
Are you using cheap or mismatched thinner? Maybe you’re confusing lack of build with losing gloss?
I’ve sprayed lots and lots of lacquer, including flow coating and/or deblushing with 75-80% thinner, and haven’t heard of this… Not to mention, rattle can stuff is incredibly thin. Tell me more about the products you’re using.
Thanks!
View cracknpop's profile
cracknpop
294 posts in 2314 days
#14 posted 09-13-2015 08:12 PM
You have been given some good advice above. To add my 2 cents…
I grew up in an automotive body shop spraying alot of lacquer, enamel, and poly-urethanes through some very nice (and pricey) spray guns. In my return to woodworking, I picked up this spray gun to see if I still knew how to spray. I am very satisfied. My 25 gal, 5hp air compressor will keep up just fine. Like suggested above, I also use an in-line air dryer. Invest in a good respirator as well. Practice spraying water on big sheet of cardboard. Have fun.
https://www.grizzly.com/products/H7669
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
MrUnix
#15 posted 09-13-2015 08:31 PM
- cracknpop
I’ve seen one of those grizzlys at a buddies house, and I’m 99% convinced it’s the same gun as the $9.99 purple HF :) Those guns are sold under a lot of different names such as Warwick and ZHipp – and I’ve seen them in at least one auto parts store on the shelf under some forgotten name. The one in the auto parts store was on sale for $69.99!
