| Forum topic by Fish22 | posted 1310 days ago | 732 views | 0 times favorited | 16 replies | ![]() |
1310 days ago |
I am newbie and figured I should ask for advice when in doubt. I am currently in the process of setting up my shop. Currently I have my table saw, miter saw, jig saw, router, orbital sander, drill and other hand tools. Since my shop is on the smaller side (12 X 16) at the moment, I will be looking at benchtop tools. Eventually I would like to add all the items on my wish list, but initially, which of the following is best to have. Drill Press Thanks -- Fish 22, South River, NJ |
16 replies so far
#1 posted 1310 days ago |
Welcome to LJs! You might add a router table to your list and with the proper bits and a quality fence you can edge joint with the router. -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#2 posted 1310 days ago |
Welcome to the site. First, you asked a loaded question. Because of the way I work, I would get the planer. But, several guys here would go for the bandsaw first. Some even would want the jointer first, but, depending on just how you are doing your work, you can joint with a planer, or with a tablesaw. Kinda going to depend on how you want to work. If you are buying your lumber at one of the box stores, you won’t need a planer. If you are working on small projects, you may not use a jointer. If you like doing bandsaw boxes, that answers that question. I guess, just get ready for LOTS of opinions. Again, welcome. -- Gary, DeKalb Texas only 4 miles from the mill |
#3 posted 1310 days ago |
Retired Coastie, I did get a router table that was on clearance at 1 of the big box guys. It was marked down from $79 to $15.01. It was too good to pass up, even if it isn’t great. Maybe I can take some parts. I haven’t set it up yet, because we are remodeling our basement and until that is done, I have been evicted from my shop area. Gary. Thanks for the heads up. Looking back I guess it is a loaded question. Thanks again. -- Fish 22, South River, NJ |
#4 posted 1310 days ago |
I would buy in the following order but this somewhat depends on what type of project you will be creating. If you will be building furniture then… 1. 12”-13” Planer (bench top planer like a dewalt or delta) By having a jointer and a planer you are able to mill your own lumber which drastically opens up the possibilities and allows you to buy rough lumber saving money. -- Brian, Folsom, CA http://www.brianfullerdesigns.com |
#5 posted 1310 days ago |
Welcome Fish22 – you have about the same setup as me. I determined the drill press was next on my list because I can buy flat/finished wood or have a lumber yard do it when I buy it. Just got one a month ago. Next on my list (Christmas) is a planer so that I can buy rough lumber and mill it myself. There are a few ways to joint without a jointer. I will get a bandsaw at some point, but my scroll saw for curves and the table saw for resawing has been making the grade so far. I did a lot of stuff with just the tools you have now…it just depends what you plan on doing. See if you can add a router table to your table saw wing to save some space. -- some day I hope to have enough clamps to need a clamp cart! |
#6 posted 1310 days ago |
Welcome Fish22. It really does depend if your going to buy finished wood or rough sawn wood as already mentioned. When I started out I was lucky enough to already a drill press because my Dad and I made a lot of things where a drill press was really handy. Mine still gets a lot of use in fact so much so it’s on it’s second motor. From your list the order I purchased those machines in was a planer, a jointer, and then the band saw. I wanted to use rough sawn lumber so the planer was a necessity. You can save money when getting rough sawn lumber and you have more variety in choosing the boards that fit your needs for the project adn the grain pattern. If you’re going to buy the finished lumber then you might want to get the drill press or the band saw first. It really does depend on the wood you plan on using and what you want to do. A hand drill will substitute for a drill press in a pinch. And yes you can have the mill joint it and plane it for you but that may negate some the cost savings of rough sawn lumber, at least around here. They might charge 25 to 50 cents a foot so on an 8 ft board that can add $2 to $4. Doesn’t sound like much but it adds up. Four 8 ft boards will add $8 to $16. Some places may even charge per pass so multiple passes to flatten a board or get it to the thickness you want can add up fast. Hence the reason I bought in the order I bought. I wanted to use rough sawn lumber and I wanted to mill it myself. Before I got the jointer I did pretty good with just the planer by choosing the rough lumber the straightest I could find it. Now I can be less picky especially if I’m going to cut the board into shorter lengths (do that before it’s jointed and planed) and even with the warp have enough on each piece to then get the thickness I want. A planer really gives you a lot of flexibility in that you can mill the thickness to what you want and not have to design around what you can buy. -- -Curt, Milwaukee, WI |
#7 posted 1310 days ago |
i have the same situation…but what my method is keep the workbench as open as possible. The only tools i have on my workbenches is my mitre saw and my scroll saw the rest is on the lower bench. my table saw is off to the side but i just slide it to the centre or outside when i need to use it. the method anyway is the less tools on top the more work space/less clustred -- My purpose in life: Making sawdust |
#8 posted 1309 days ago |
Don’t think I could live without a drill press… they are cheap as can be… why not just get them all though… You’ve been a good boy… -- There is a fine line between eroticism and nausea... |
#9 posted 1309 days ago |
I would get a copy of the book “Setting up Shop” It has a lot of good info and can help you make an informed decision on what your tools needs would be. There are a lot of variables to answer your question. What are you planning on building? It is cabinets, you will need a good table saw. Is it small boxes? Is it fretwork? Get a copy and read it, I think you will be amazed how much info is needed in making that decision. You have started in the right place by asking here, there are a lot of talented people here and they all have good ideas and opinions, but remember those opinions are their own. Please dont misinterepet this post as being negative. Its not, the book is very good and has helped me a tremendous amount -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
#10 posted 1309 days ago |
Of the list you gave us, I would get the drill press. Jet makes a very nice bench-top that is pretty new to their line for about $300. Yes, there are cheaper versions out there, but as I will always say, you get what you pay for. That said, I agree with Ken. There is no way to answer this without out knowing what you intend to do. -- She thought I hung the moon--now she just thinks I did it wrong |
#11 posted 1309 days ago |
Like some guys have said, it depends on what you build and your situation. Do you use pre-surfaced lumber or are you looking to start using rough lumber? Do you build shaker style with a lot of straight lines or custom stuff with a whole bunch of curves? I have the same situation as you, my shop is about the same size and I currently have about the same tool list. A jointer is nice to have but when you are in a small shop a jointer takes up a lot of real estate, I was really looking at getting one but I couldn’t do it because it took up so much room. With the planer, you can build a sled and use that as “your jointer” when cleaning up the first face. But like I said, do you use pre-surfaced or are you thinking of using rough lumber? A band saw is a great machine to have but like I said, what kind of work do you do. It’s great for re-sawing, curves, and much more. I don’t know how many times I have said, “I wish I had a drill press” when trying to drill a straight hole with a hand held drill. Plus you can get drum sanding attachments and a mini “spindle” sander. My opinion order would be planer, drill press, band saw, and jointer. |
#12 posted 1309 days ago |
I would buy in this order Planner -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#13 posted 1309 days ago |
Thanks for all the different advice. Like I said, I am new, so a lot of the projects I have in my head may be for down the road. Initially I plan on building a couple of book cases and other needs around the house and the shop of course. -- Fish 22, South River, NJ |
#14 posted 1309 days ago |
Jim he mentioned he bought a router table already. -- -Curt, Milwaukee, WI |
#15 posted 1308 days ago |
I think you might find the Drill press most helpful. -- With each new day, celebrate life. Love God with all of your heart. Share Jesus with those around you and make a positive impact on those you meet. Bob |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15980 |
Hand Tools
2097 |
Jigs & Fixtures
501 |
Wood & Lumber
2907 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
