Fininshing touches for workbench top
Forum topic by Catamount posted 09-11-2015 07:40 PM 728 views 0 times favorited 5 replies Add to Favorites Watch
View Catamount's profile
Catamount
16 posts in 2128 days
09-11-2015 07:40 PM
Hi All
I have now nearly completed my new workbench. The top now has 3 coats of Waterlox applied and now for the question.
Should I wax the top to prevent glue from sticking or should I leave it along for “tooth” when working with wood?
What do you all think?
Thanks
Al
-- VERMONT The land of the colorful fall - Just before the cold and the ice and the snow and the below zero temps
5 replies so far
View Richard H's profile
Richard H
489 posts in 1735 days
#1 posted 09-11-2015 07:45 PM
What are you using the workbench for? If you are using hand planes on the surface I would leave it with tooth, if you are using it as an assembly/finish table I would wax it so glue/finish doesn’t stick. If you are using it for both like I do you can go either way. I don’t finish my tops but I don’t care to much what the top looks like either. Mine have dried glue and chisel marks and the occasional errant drill hole all over them.
View JayT's profile
JayT
5729 posts in 2265 days
#2 posted 09-11-2015 07:57 PM
I would not wax a workbench top. Finishing table, yes. Workbench, no.
View bobasaurus's profile
bobasaurus
3501 posts in 3238 days
#3 posted 09-11-2015 10:08 PM
If you ever plan on refinishing it, don’t wax the surface… nothing will ever stick to it after.
On my crappy bench I only use wax as a top finish so I can glue things on it and just scrape the blobs off after.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View paratrooper34's profile
paratrooper34
915 posts in 3006 days
#4 posted 09-12-2015 12:33 AM
When I got my bench, it was unfinished from the factory. I gave it a HEAVY coat of BLO. I have had it for about five or six years now and have re-coated it once. I use my bench for everything including glue ups and finishing. For times I missed some glue drippings, I found they slide right off with a scraper. I definitely will not wax it ever. I like the surface to have some “grip” to it.
-- Mike
Catamount
#5 posted 09-12-2015 01:54 AM
Thanks guy’s
I guess I will leave as is. If I wax it I can never go back so that seems like the best option,
Al
