Hickory drawbored pins?
« back to Hand Tools forum
Forum topic by newwoodbutcher posted 09-11-2015 06:47 PM 557 views 0 times favorited 2 replies Add to Favorites Watch
View newwoodbutcher's profile
732 posts in 2783 days
09-11-2015 06:47 PM
I’m building a work bench for myself. The top will be 4”- 4 1/2” thick Ash,the legs and stretchers will be made from a section of re-purposed hard maple bowling ally lane. The approximate size of the legs will be (depending on the available material) 5 1/2” x 3 -4” . I’m thinking I’ll use through tenons to attach the legs to the top. Draw-bored (3/8”) and wedged (Overkill, I know) and Draw-bored Mortise and Tenon joints for the 2”x6” stretchers.
I also have quite a bit of left over scraps from a solid Hickory hardwood floor installation.
I’ve only heard of people using Oak for Draw-bored pins. Question, will hickory pegs work as well as Oak?
-- Ken
2 replies so far
View pintodeluxe's profile
5595 posts in 2747 days
#1 posted 09-11-2015 06:52 PM
Yes, hickory will work just fine.
Wedged tenons are not needed in drawbored M&T joints, but you could do it for looks I guess.
#2 posted 09-11-2015 07:22 PM
Thank you. It’s one of those very few times I can justify holding on to scraps, “I knew I’d use it some day” . I know the wedges are overkill, but I like the idea. I’ll probably use black walnut for the wedges.
-- Ken
