DEFINITIONS EVERY HANDYMAN SHOULD KNOW....
« back to Coffee Lounge forum
Forum topic by ChicoWoodnut posted 11-16-2009 06:11 PM 2322 views 0 times favorited 11 replies Add to Favorites Watch
View ChicoWoodnut's profile
ChicoWoodnut
904 posts in 4050 days
11-16-2009 06:11 PM
Haven’t posted in a while but I thought you guys would enjoy this.
Tool Definitions
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, “Oh, shit!”
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of Blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle … It Transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit usually smashing the thumb that is holding the object that you are trying to pound into whatever it is that you are working on effectively eliminating the need for manicure care on that thumbnail for weeks. See: Son of a b…tch TOOL
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a b…tch TOOL:
Any handy tool that you grab and throw across the garage while yelling, “Son of a b…tch” at the top of your lungs. It is also, most often, the next tool that you will need.
11 replies so far
View Mike Gager's profile
Mike Gager
665 posts in 3502 days
#1 posted 11-16-2009 10:39 PM
yup pretty much have them all, with missing fingerprints to prove it
View GMman's profile
GMman
3902 posts in 3932 days
#2 posted 11-17-2009 03:33 AM
You’re right
View Mark's profile
Mark
1813 posts in 3509 days
#3 posted 11-17-2009 04:10 AM
SOOOOO TRUE!
-- M.K.
View Napaman's profile
Napaman
5530 posts in 4312 days
#4 posted 11-17-2009 04:57 AM
ouch…now I have a better understanding of all the tools…
good to see you!
-- Matt--Proud LJ since 2007
View huff's profile
huff
2828 posts in 3520 days
#5 posted 11-17-2009 05:08 AM
......and I’ve proved the definition of each and every one of those tools!
-- John @ http://www.thehuffordfurnituregroup.com
View nmkidd's profile
nmkidd
758 posts in 3408 days
#6 posted 11-17-2009 10:48 AM
I personally have all those tools….been there…....done that!
-- Doug, New Mexico.......the only stupid question is one that is never asked!........don't fix it, if it ain't broke!
View Allison's profile
Allison
819 posts in 4034 days
#7 posted 11-17-2009 06:22 PM
This is hysterical and so true. LOL!!! By the way how are you doing? My closest neighbor here at L.J.’s
-- Allison, Northeastern Ca. Remember, Amateurs built the Ark. Professionals built the Titanic!
View Festool4's profile
Festool4
78 posts in 4013 days
#8 posted 11-18-2009 04:15 PM
I must say that I have many of these tools as well…
-- Festool4
View Dano46's profile
Dano46
85 posts in 3404 days
#9 posted 11-18-2009 07:42 PM
That was very enjoyable reading.
-- You can't trust a dog to guard your food.
View Andrew Betschman's profile
Andrew Betschman
309 posts in 3458 days
#10 posted 12-09-2009 02:50 AM
That was quite good.
-- Andrew, Ohio https://www.etsy.com/shop/AndrewBetschman
18618 posts in 4396 days
#11 posted 12-09-2009 01:16 PM
heheh .. ah.. yup!! :D
-- ~ Debbie, Canada (https://www.facebook.com/DebbiePribele, Young Living Wellness )
