My Dust Collection Setup
Forum topic by Bill7255 posted 09-11-2015 01:49 PM 1671 views 0 times favorited 3 replies Add to Favorites Watch
View Bill7255's profile
Bill7255
427 posts in 2309 days
09-11-2015 01:49 PM
Topic tags/keywords: bandsaw
I have just recently finished setting up my DC system. I have been a hose dragger for about 15+ years and decided with my new shop I would install a system.
My shop is a 30’ X 50’ pole barn, however I also use it for my lawnmower, Gator, and garden tools. That took a 12’ X 16’ footprint and I put in a half bath, another 6’ X 8’ footprint. I lost space, but did not want to maintain another out building. I did everything the least expensive way I could, but wanted a decent system. I am very happy with the results. I used 6” 30ga duct and fittings. I previously did testing and found by adding a plywood ring midway of the pipe would eliminate any chance of collapse in the duct and none of the fittings showed any sign of deformation in my testing. http://lumberjocks.com/topics/87690
I built my system using my Jet 1900 3hp four bag DC. I had also purchases a EBay cyclone. I also purchased two Wynn filters, but I ended up venting outside.
My drum sander, router table and jointer/planner I move to an open area and hook up to a 6” flex hose drop. Just don’t have the room to make everything stationary. All of the other tools are connected and blast gates are installed.
Since I had so much 4” hose from my hose dragging days I used some for a 20’ floor sweep for the lathes It also reaches the table saw area. I put a piece of 6” PVC for sanding dust for the large lathe and the small lathe has a Big Gulp.
The results! I have planned and joined about 7 eight foot by 7” hard maple boards and have run the drum sander about 6 hours making some cutting boards. The first picture is the second barrel, it has one joined/planned board chips on the bottom and the top half was from the drum sander. The second picture shows the outside exhaust area. Just a little light dust there. I put a finger mark on the trailer to try and show the extent. I am very satisfied with the results.
Total cost for everything was around $1400. I had $700 from previous (includes $300 for used Jet 1900) and spent another $700. This doesn’t include $400 I spent for 2 Wynn filters I now need to sell and will loose about $250 on that, bringing the total to $1650.
I still ill have work to do such as building a miter saw table and enlarging ports where possible. Conclusion, yes a definite performance increase using 6” duct. IMO the EBay cyclone performs very well, better than I anticipated.
-- Bill R
3 replies so far
4999 posts in 2517 days
#1 posted 09-11-2015 02:17 PM
Well done, looks really good. I see you were able to find actual wye’s for your ducting. Most importantly, you’re happy with it!
View Notw's profile
Notw
649 posts in 1778 days
#2 posted 09-11-2015 03:27 PM
Very nicely done, I have been toying with the idea of venting outside, my system goes through a Thein baffle on a 32 gal trash can. Looks like the impact would be minimal so maybe my neighbors wouldn’t notice
Bill7255
#3 posted 09-11-2015 05:08 PM
Thanks Fred. I had to reverse the crimps on the wyes.
NotW. I used the Thien before I set this up. It would work for outside and captured chips very well. However it was only about 75% efficient using the drum sander. No where near as well as the cyclone I would say is 98% effective. But that is fine dust bypassing the Thien and may just blow away.
-- Bill R
