confused, need advice
Forum topic by jeffswildwood posted 09-11-2015 01:24 PM 829 views 0 times favorited 5 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3320 posts in 2028 days
09-11-2015 01:24 PM
Topic tags/keywords: question
Hello all. I have a question that I can’t seem to wrap my mind around. I assembled the pieces of my treasure chest and placed the rabbets on the blocks prior to assembly. I am doing six of these boxes and with the blocks rabbeted I just didn’t trust my small router table to make two start stop rabbets on each of the tops and bottoms. That would be sixteen start stops per box times six boxes! I chose instead to use my router guide and go from rabbet to rabbet while the panels are assembled. This way I could see what I am doing and start and stop at the correct point. My question, should I go left to right or right to left? I will place the guide an the bottom of the panel and going across the top inside. Simple question but I seem confused. I think left to right, is that correct?
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
5 replies so far
View CB_Cohick's profile
CB_Cohick
487 posts in 1302 days
#1 posted 09-11-2015 01:30 PM
Routing by hand on an outside edge using the router guide, go counter-clockwise.
-- Chris - Would work, but I'm too busy reading about woodwork.
jeffswildwood
#2 posted 09-11-2015 01:33 PM
I tried to post a picture but it just didn’t post. If you go to my home page and scroll down there are pics of the panels that make up the sides and you can tell better what I am asking.
jeffswildwood
#3 posted 09-11-2015 01:34 PM
CB, It will be an inside edge.
jeffswildwood
#4 posted 09-11-2015 04:16 PM
OK, I did a little trial and error on some assembled scrap and got it down now. left to right, or clock wise since it’s on an inside cut. CB was correct if I was cutting on the outside of the panel, but this is an inside cut.
View Daruc's profile
Daruc
460 posts in 1183 days
#5 posted 09-11-2015 04:22 PM
Just remember the cutters teeth always should cut into the material as you pull.
