Rewiring Delta 34-444 Table Saw
Forum topic by sjbob posted 11-16-2009 06:07 AM 4938 views 1 time favorited 1 reply Add to Favorites Watch
View sjbob's profile
sjbob
16 posts in 3479 days
11-16-2009 06:07 AM
Topic tags/keywords: tablesaw wiring
I thought I would post the information I received from Delta in 1997 on how to wire the Delta 34-444 (circa 1990) table saw for either 115 or 220 VAC. I’m doing this because I’m pretty disappointed that this is not a standard set of information in the user manuals, and thought it would be good to have it archived in the internet.
Here is the information, verbatim:
Remove cover from wiring compartment in motor endbell. Inside the compartment you will find different color wires hat terminate in quick connect terminals. These wires are connected to 1/4” male spade terminals which are secured to a white plastic terminal board. The 1/4” male spade terminals are marked with the numbers 1,2,4,5,6.
For 115 volts:
a. Brown and red motor leads are connected to terminal 2
b. Blue motor lead is connected to terminal 4
c. Line 1 of power cord is also connected to terminal 4
d. line 2 of power cord is connected to terminal 1
To reconnect for 230 volts:
a. Remove brown motor lead from terminal 2 and connect it to terminal 6.
b. Remove blue motor lead from terminal 4 and connect it to terminal 2.
c. Do not touch power line connections. Leave them connected to terminals 1 and 4.
Replace the cover on the wiring compartment. Cut the 115 volt attachment plug off the power supply cord and install a 230 volt attachment plug.
-- Every project is a learning experience.
1 reply so far
TopamaxSurvivor
18291 posts in 3704 days
#1 posted 11-16-2009 06:29 AM
It probably depends on the motor manufacturer. Some have spade connections as described, others just have numbered wires connected with wire nuts, some just have color coded wires, ect….
