Solid wood or plywood?
Forum topic by GT350 posted 09-09-2015 01:00 PM 960 views 0 times favorited 13 replies Add to Favorites Watch
View GT350's profile
GT350
361 posts in 1858 days
09-09-2015 01:00 PM
Hi all, I am going to build a couple of dressers out of Cherry, they will have solid sides not frame and panel. The question I have is what would be best, solid wood or plywood. I have always preferred solid wood and I am looking to build heirloom quality dressers. I don’t like plywood as well because of the thin veneer and I will account for wood movement on the sides and tops. What would you do and which would have the longest life?
Thanks
Mike
13 replies so far
View bondogaposis's profile
bondogaposis
4542 posts in 2228 days
#1 posted 09-09-2015 01:05 PM
Heirloom quality = solid wood.
-- Bondo Gaposis
4832 posts in 2370 days
#2 posted 09-09-2015 01:08 PM
Skipping the “what is best” question, I would use plywood. It’s not perfect, even more so with cherry and the color matching problems. But plywood has a lot of advantages (in my book) and I use it for most stuff that has a large panel as opposed to gluing that panel up from solid wood. This question comes up from time to time, and past replies show I’m in the minority…but that’s never bothered me before. It is, after all, only my opinion. That said, if I was building something I think would truly be heirloom quality; I would use solid wood.
View helluvawreck's profile
helluvawreck
29804 posts in 2743 days
#3 posted 09-09-2015 01:21 PM
From your post you prefer solid wood. You can obviously build an heirloom dresser with solid wood so I would definitely use solid wood. If you decide to use plywood I would make sure that you used the best and buy it from a store where you can look thru a ‘few’ sheets to eliminate warped sheets and small defects.
helluvawreck aka Charles
View shipwright's profile
shipwright
7856 posts in 2675 days
#4 posted 09-09-2015 02:50 PM
Personally I’d use high quality plywood and do my own veneering. If high quality plywood had been available a couple of hundred years ago we would have a different concept of “heritage quality”. ....... IMHO
View sawdust703's profile
sawdust703
270 posts in 1297 days
#5 posted 09-10-2015 02:55 PM
From your post, your preference is wood. Use wood. And if you’re making a family heirloom, I’d use wood. You’ll be a lot happier with the strength, looks, & it’ll hold up over time. Forget the plywood on this project, if it were me.
-- Sawdust703
GT350
#6 posted 09-16-2015 02:44 AM
Thanks for the comments, I will post pictures when I am done.
Mike
View pintodeluxe's profile
pintodeluxe
5546 posts in 2690 days
#7 posted 09-16-2015 05:22 AM
I think frame and panel with solid wood panels is a good way to go. It solves the significant issue of wood movement, and looks great with most styles.
My second choice would be solid wood sides.
Third choice would be wood frames with 1/2” premium plywood panels, which also looks very good.
View mahdee's profile
mahdee
3831 posts in 1644 days
#8 posted 09-16-2015 12:26 PM
You always can combine the two as shipwright suggested. Use 1/2” plywood and 1/4” cherry solid wood.
-- earthartandfoods.com
View ChefHDAN's profile
ChefHDAN
1007 posts in 2726 days
#9 posted 09-16-2015 05:21 PM
+1 for using both though finding good 11 ply veneer ply can be difficult, I drive a 3 hour round trip to get it. This project has QS cherry for the end panels, face frame, doors, and the shelf fronts, the top is still in progress, but it will be solid 1” cherry with a border inlay. The rest of the cab is 3/4” 11 ply cherry veneer ply wood and the back is 1/4” veneer core plywood.
GT350
#10 posted 09-16-2015 05:57 PM
I haven’t thought about inlays, that would be a nice touch. I have multiple pieces with frame and panel so I thought just to mix things up I would go with solid sides.
Mike
View AlaskaGuy's profile
AlaskaGuy
3800 posts in 2186 days
#11 posted 09-16-2015 07:00 PM
Well it depends, either will work. It depends on what you want, your skill level, what tools you have, how much time and money you want to spend and other stuff.
I tend to go with solid wood for something like a dresser. A dresser in my mind is more a piece of furniture than a cabinet. It think you have more design possibilities with solid wood than with plywood because you don’t have to worry about the exposed edges of plywood.
For a dresser with solid wood doesn’t have to be frame and panel. It can be as simple as 4 glued up panels joined at the four corners with dovetails, box joints or what ever you like.
ChefHDAN
#12 posted 09-16-2015 08:15 PM
DAUM Alaskaguy! Thatsa nice dresser!!! LOvethe feet and the DT drawer frames are Nice! Do you do a full dust frame for the drawer or install slides?
AlaskaGuy
#13 posted 09-16-2015 08:53 PM
No dust frames. This is where some would say I cheat but I just hung the drawer on full extension drawer slide. Not because it’s easier but because I like the functionally of the full extension slides.
Thanks for you comment.
