Removing glue from clamps
Forum topic by Routerisstillmyname posted 11-15-2009 05:01 AM 1133 views 0 times favorited 7 replies Add to Favorites Watch
View Routerisstillmyname's profile
Routerisstillmyname
763 posts in 3509 days
11-15-2009 05:01 AM
Topic tags/keywords: question
Can anyone recommend a product that will remove/strip hardened Polyurethane ( as in Gorilla) glue from clamps.
THX
-- Router รจ ancora il mio nome.
7 replies so far
View LesB's profile
LesB
1728 posts in 3443 days
#1 posted 11-15-2009 06:17 AM
A grinder? Try acetone soak.
-- Les B, Oregon
View childress's profile
childress
841 posts in 3542 days
#2 posted 11-15-2009 07:54 AM
I’d try a wire wheel on an angle grinder. I use an air powerd one because it’s smaller and easier to control. I havn’t tried it on poly glue, but it works fine on yellow glue. Can’t imagine it would be any harder to remove.
-- Childress Woodworks
27250 posts in 3822 days
#3 posted 11-15-2009 03:17 PM
Cured poly is tough to remove. About the only thing that will take it off is scraping and/or sanding. Putting a coat of wax on the clamps between usage helps make removing hardened glue easier.
View mtkate's profile
mtkate
2049 posts in 3325 days
#4 posted 11-16-2009 12:00 AM
I spent a long time a little while ago chipping away at the clue on my metal clamps with a scraper. Lots of elbow grease needed. Now I am sure to cover them with duct tape if there is a question of major seepage.
View Mark's profile
Mark
1807 posts in 3274 days
#5 posted 11-16-2009 12:02 AM
i just put blocks between the project n my clams
-- M.K.
View hairy's profile
hairy
2704 posts in 3532 days
#6 posted 11-16-2009 12:40 AM
This isn’t what you want to hear, but, waxpaper keeps it from getting it on there.I have taped waxpaper to the glue up, then put the clamps on.Or , tape it to your clamps. Or, tape your clamps with masking tape, then tear it off later.
-- My reality check bounced...
View cstrang's profile
cstrang
1832 posts in 3168 days
#7 posted 11-16-2009 01:24 AM
Get an old chisel and a real hammer, I know… never hit a chisel with a hammer but you need some force behind this one lol.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
