Whiteside Router bit gel
Forum topic by acencha posted 11-14-2009 10:52 PM 2108 views 0 times favorited 3 replies Add to Favorites Watch
View acencha's profile
11 posts in 3074 days
11-14-2009 10:52 PM
I’ve been lurking this site for about 1 – 2 months and like the very informative community and information.
I recently purchased a whiteside router bit, and it came covered in a thick layer of gel type coating.
What should I use to remove it without harming the cutting tips? OR, should I leave it on?
3 replies so far
View Ger21's profile
1074 posts in 3066 days
#1 posted 11-14-2009 11:14 PM
It should be more of a soft rubber than a gel. You should be able to peek it off with your fingers. Just watch out for the sharp edges. I sometimes will use an awl skid in along the shank to get it started.
-- Gerry,
View AaronK's profile
1505 posts in 3399 days
#2 posted 11-14-2009 11:20 PM
i’ve had bits come in that gel stuff, cosmoline, and wax. i use whatever works – alcohol, mineral spirits, thinner – whatever organic solvent there is with no adverse affects. as long as you dont use anything awfully acidic or abrasive, you should be ok.
#3 posted 11-14-2009 11:25 PM
Alrighty, got it off.
I just had to scrape it off.
