Delta Table Saw Blade Insert
Forum topic by Mark731 posted 09-06-2015 10:37 PM 595 views 0 times favorited 2 replies Add to Favorites Watch
View Mark731's profile
Mark731
3 posts in 960 days
09-06-2015 10:37 PM
Topic tags/keywords: table saw
I purchased a delta 36-725 10” table saw recently. The insert that came with the saw does not lay flush with the rest of the surface of the table saw. This creates issues when cutting wood. I do not see any adjusting screws to work with to make it flush. Has anybody out there seen this or have some advice ?
2 replies so far
View Rayne's profile
Rayne
683 posts in 1408 days
#1 posted 09-06-2015 10:56 PM
There are screws in the insert recess that you adjust to make it flush.
View WhyMe's profile
WhyMe
934 posts in 1430 days
#2 posted 09-06-2015 11:24 PM
There are small holes (5) in the insert that you can stick a small phillip screw driver in to adjust the screws in the recess of the cast iron top. If you have no screws then they are missing.
