Complete Woodworking Center in less than 4 square meteres
Forum topic by Brendon posted 09-06-2015 01:06 PM 2346 views 3 times favorited 12 replies Add to Favorites Watch
View Brendon's profile
Brendon
45 posts in 1294 days
09-06-2015 01:06 PM
Here is my new woodworking centre: It comprises a saw table with outfeed surface,a router table, an router gantry for flattening boards and slabs, 9-drawer tool storage.
The outfeed table doubles as an assembly table or work surface. The saw table fence reverses for use with the router table; it only takes a few seconds to unlock two mag-switches and lift off the fence and reverse it. The router gantry utilizes a 1/2” Trend Router. There is an gang of electrical sockets in front of the router table and another one behind the outfeed table; very handy for various power tools. I also have a Crosscut Sled for the saw table. The tool storage is great and has ensured that I no longer mislay hand tools about the shop. Work can be clamped onto the work surface when working behind the unit or in front by opening the top drawer slightly to allow clamps to reach under the surface.
The set up has freed up my main workbench which heretofore acted as an assembly table as well. It has also freed up floor space as I no longer need a dedicated space for a router table.
-- Brendon, Ireland
12 replies so far
View canadianchips's profile
canadianchips
2600 posts in 2902 days
#1 posted 09-06-2015 01:15 PM
Nice looking router table extension on saw. Did you build it or buy it ?
You put yours on same side of saw I did. Others use right side, not sure why, I like mine on left.
View thirdrail's profile
thirdrail
54 posts in 2569 days
#2 posted 09-06-2015 03:30 PM
Brendon-
Nice job!
Sure would like to see a few more photos of your router gantry. I see the wedges to secure the board but what are you wedging against? Is the slot in the gantry set up for only one pass on each set of the gantry or for multiple passes?
Is the whole thing a scratch built or does it incorporate a map case?
Anyway, great idea and execution.
Bart
-- Third rail
View bonesbr549's profile
bonesbr549
1493 posts in 2972 days
#3 posted 09-06-2015 05:00 PM
Nice setup! I bet you love your Knew concepts saw, I know I love mine!
View MrRon's profile
MrRon
4632 posts in 3149 days
#4 posted 09-06-2015 07:12 PM
Well done Brendon. You prove my point that all it takes is ingenuity and imagination to do what others may consider impossible. I have 1200 sf (111 sq mts) of shop space and I don’t have enough room. I’m just not as organized as you, but should be.
Brendon
#5 posted 09-06-2015 07:40 PM
- canadianchips
Hi,
Thanks for your message. The router tables was cut down from one I had bought at some time or other, and I set it in between the bars on the LHS of my saw . It just happens that everything is to the left of my saw.
B
-- Brendon, Ireland
Brendon
#6 posted 09-06-2015 07:43 PM
Brendon-
Nice job!
If I get a chance I’ll take a few more pics over the next few days and post them. I’ll show a piece of wood wedged in. One pass only on each set of the gantry. Scratch built. I don’t need to flatten slabs that often but when I do this does the job.
B
Bart
- thirdrail
-- Brendon, Ireland
Brendon
#7 posted 09-06-2015 07:44 PM
- bonesbr549
Aha! so you’ve been looking in my drawers. Yep, the Knew Concepts Saw is cool.
B
-- Brendon, Ireland
Brendon
#8 posted 09-06-2015 07:46 PM
Well done Brendon. You prove my point that all it takes is ingenuity and imagination to do what others may consider impossible. I have 1200 sf (111 sq mts) of shop space and I don t have enough room. I m just not as organized as you, but should be.
- MrRon
I have a fairly big shop too but I do metalwork as well so lathe, mills and grinder take up space. I was getting to the stage where I was tripping over stuff so i had to do something.
Thanks for your interest.
B
-- Brendon, Ireland
View Kazooman's profile
Kazooman
932 posts in 1857 days
#9 posted 09-06-2015 08:54 PM
Very nice! An ingenious use of available space.
I did notice that you do not have any relief slots in your out feed table that match the miter slots on the saw and router table. i couldn’t use my cross cut sled without having the guide run out into the extension table. Do you have a work- around to avoid the need for the slots?
Brendon
#10 posted 09-06-2015 09:20 PM
Hi, Thanks for your message. I don’t need the slots. There is a bit of a gap (not much but you can see it in one of the photos) between the saw table and the outfeed table and my sled is not quite as deep from front to back as many sleds are. Added together these mean that I just make it without the need for slots.
Cheers
B
-- Brendon, Ireland
Brendon
#11 posted 09-07-2015 10:52 AM
Brendon-
Nice job!
Ok Bart, Here are a few pics showing the set-up.
As you can see here at one end I have a Flip Stop that catches the ends of two rails. The two rails are clamped to the table at the other end. These act as something to wedge against. I show a workpiece wedged in place for the photo. It only takes a couple of minutes to set this up.The next pic shows the clamps at the other end.
The next pic is a view into the gantry.
Now, a pic of the end supports showing the system for raising or lowering.
And finally a pic of the sliding wedges.
I hope this makes things a little clearer.
B
-- Brendon, Ireland
thirdrail
#12 posted 09-07-2015 12:55 PM
Brendon-
Thank you very much for posting the router gantry photos. Again, congratulations on your nifty woodworking center.
-- Third rail
