Upgrading my planer
Forum topic by Beauman22 posted 09-06-2015 01:35 AM 1026 views 0 times favorited 12 replies Add to Favorites Watch
View Beauman22's profile
Beauman22
5 posts in 1055 days
09-06-2015 01:35 AM
It’s time to upgrade my planer from a 13 inch dewalt to a 20 inch planer.
I was originally planning on getting a new grizzly G0454Z with the shelix or finding a used on but then I came across something that is way more budget friendly on Craigslist. A g1033 made in 1999. 3 HP straight knife 4 post design in really good condition asking 6 hundred. I figured if it’s a good machine and I like it I could upgrade it too the Byrd cutting head.
My only concern is it being a 3 horsepower instead of 5 horsepower like the new ones. Is it more then enough power ?
12 replies so far
View toddbeaulieu's profile
toddbeaulieu
810 posts in 2910 days
#1 posted 09-06-2015 02:59 PM
I have a Grizzly 15” that I thought would obsolete my lunchbox. It did not. I suggest whatever you get to keep your lunchbox until you’re convinced no longer need it. I find that I can sneak up on the thickness easier with the lunchbox. The Grizzly (at least mine) has a knurled feed roller, which leaves marks in the stock if I don’t take off enough in the pass. The teeth go deeper than the cutters.
The Grizzly’s got much more adjustability, but with that comes the need to understand how to adjust it and I’m not convinced mine is set up properly.
As for HP, that of course, depends on your use but for me I’d never need that much. 3HP is a good amount of power IMO and unless you’re trying to hog off a massive amount of material in a pass, 3 HP is pretty nice.
4879 posts in 2399 days
#2 posted 09-06-2015 03:23 PM
I have a Delta 15” with 3 HP, and it does indeed seem to be plenty…..even if the planer was 5” wider. That said, for the price you getting the 1033 for, even if it’s a little underpowered it may still be well worth buying. What Todd mentioned (the serrated infeed roller) is worth noting, it’s very hard to take a really thin cut on the last pass…it has to be deep enough to get the infeed marks. There’s also considerably more maintenance than a lunchbox…occasional gear box oil changes, and chains to lube, etc. Lot more chips as well, may need to add or upgrade the DC. Lots of advantages as well, quieter (especially with a spiral head), handles the toughest woods without a wimper, all day if needed. I’d sure give that 1033 a good look.
View buildingmonkey's profile
buildingmonkey
242 posts in 1453 days
#3 posted 09-06-2015 07:09 PM
The G1033 is a step up from the G0454. I’d be all over it. They sell a helical cutterhead for it.
-- Jim from Kansas
View Redoak49's profile
Redoak49
3076 posts in 1894 days
#4 posted 09-06-2015 08:26 PM
A Byrd head for a 20” planet is around $1400.
It all comes down to what you are going to use it for. S o many questions on the forum ask if someone should buy something. The first question is what are you going to make and that usually answers the question.
I have a 15” planer and a DW735 and use them both. As mentioned, the issue of the serrated infected roller is important. My DeWalt is great for taking small amounts.
toddbeaulieu
#5 posted 09-06-2015 09:15 PM
You know what else I find myself doing a lot with both planers is leaving the dewalt set up to finial thickness and working my way down to it when making additional pieces after realizing that I didn’t make enough “extras”. More times than I’d like to admit.
Beauman22
#6 posted 09-06-2015 09:24 PM
- Redoak49
I use my lunchbox planer for dimensioning rough stock. I’m planning on using the twenty inch for dimensioning rough stock as well. I’m also planning on it flattening glue ups. Stuff like cutting boards, shelves, table tops in sections, etc.
Beauman22
#7 posted 09-08-2015 02:48 PM
I bit the bullet and ordered a new grizzly twenty inch spiral cutter head planer as all my craigslist leads fell through. I get it in a few days and will post what I think about it after assembly.
Thanks
Nick
toddbeaulieu
#8 posted 09-08-2015 03:03 PM
Wait! That is NOT fair!
View AZWoody's profile
AZWoody
1265 posts in 1130 days
#9 posted 09-08-2015 03:03 PM
Thanks
Nick
- Beauman22
I have that planer and it runs very smooth. Just remember, as someone else mentioned earlier. Make sure you take a large enough bite on your final pass or you’ll have a lot of sanding to do as the infeed rollers will leave marks all along the wood.
View rwe2156's profile
rwe2156
2799 posts in 1386 days
#10 posted 09-08-2015 03:14 PM
I have the 1033 sans helical cutterhead very happy with it.
I’ve never had a problem with power.
With the helical head you’ll have an awesome machine.
FYI, the castings are the same as a Powermatic.
View Dabcan's profile
Dabcan
255 posts in 2577 days
#11 posted 09-08-2015 11:31 PM
I replaced my Rigid lunch box planer with a 15” general after some fairly exciting pyrotechnics came out of the Rigid. I wish I would have purchased the General years ago. It has a nice finish, extra width, way more power, and much quieter.
I’d wonder if you’re saving much in the end buying used and upgrading the cutter head versus buying new with a cutter head? Think of the time you’ll be spending tuning up the old planer and then all the time spent replacing the cutter head, maybe you’d rather spend this time making things? I know I would
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
buildingmonkey
#12 posted 09-18-2015 05:51 PM
Just looked at my Grizzly catalog, and a 20” helical cutterhead is 1095. They get them on sale occasionally, I’d wait for that if I were getting one. Every machine I have was bought on sale, or used.
-- Jim from Kansas
