How to work with bloodwood
Forum topic by reddinosaur posted 11-14-2009 01:03 AM 1756 views 0 times favorited 8 replies Add to Favorites Watch
View reddinosaur's profile
reddinosaur
120 posts in 3326 days
11-14-2009 01:03 AM
Topic tags/keywords: bloodwood drill drilling pen pen making drill press turning i cant think of anymore tags
I recently bought some 5/8×5/8 blanks for pens that are blood wood. While attempting to drill a 10mm hole through, the blank fell apart. I went in very slowly and blew away the chips about every 1/4”. The blank was clamped in a drilling vice with v-blocks to hold it in place.
What else can I do to prevent the splitting?
-- Jess
8 replies so far
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3381 days
#1 posted 11-14-2009 01:05 AM
Just curious, did you use a brad point or standard twist bit?
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
teenagewoodworker
2727 posts in 3966 days
#2 posted 11-14-2009 01:22 AM
also was it a drill press or an hand drill. ive done that before splitting pieces with my hand drill because i move around a bit.
35146 posts in 4598 days
#3 posted 11-14-2009 01:48 AM
I like a brad point drill bit and like you say In out, in, out don’t let chips get impacted in the gillets of the drill bit. Make sure the drill bit is clear of chips before you put it back into the blank.
I noticed that you had 5/8” blanks and were drilling a 10MM hole. You are pushing the envelope there The wood heats up real fast and any internal pressure will cause it to split.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
View Mark's profile
Mark
1809 posts in 3472 days
#4 posted 11-14-2009 03:03 AM
use a drill press with a 3/8” forstner bit n take your time
-- M.K.
reddinosaur
#5 posted 11-14-2009 04:18 AM
I used a brad point on a drill press. I really did go slow and take out the chips. I know the sizes are pushing it but now that I have these blanks I figure I’ll just do my best with it. Lesson learned lol
Should I wait for the wood to cool? Like drill a tiny bit and just go back to it later to drill more? I’m thinking about starting with 1/8” drill and working my way up. Any thoughts on that?
Thanks for all the help! I really appreciate it =]
-- Jess
View Mark's profile
Mark
#6 posted 11-14-2009 04:37 AM
well if u have a forstner bit 3/8”try the method i mentioned…the forstner bits reduce alot more burning than a normal bit. And yes wait for wood to cool. And depending on how experienced and accurate you are on drilling several times on the same spot small size to big size try it out ive never tried that. it doesnt hurt to try.
-- M.K.
TopamaxSurvivor
18388 posts in 3874 days
#7 posted 11-14-2009 04:55 AM
i doubt if successive sized drills will solve your problem. Chips building up in the twist of the drill are probably causing too much pressure for the small blank to take. The forstner bit has a lot more space for them to go. Or maybe a very small auger type bit will work better. They don’t have as much suface contact to generate heat.
reddinosaur
#8 posted 11-14-2009 07:12 AM
Would using a wood stabilizer be an option?
-- Jess
