Childrens toy finish
Forum topic by WAWoodButcher posted 11-13-2009 06:34 PM 1371 views 0 times favorited 10 replies Add to Favorites Watch
View WAWoodButcher's profile
WAWoodButcher
18 posts in 3354 days
11-13-2009 06:34 PM
Good morning to all. I am looking for a topcoat to put on childrens toys I make. Something that is durable, preferably easy to apply, clear, and because it is amazing what kids chew on, non toxic. Thanks for any ideas.
-- "Maybe, just once, someone will call me 'Sir' without adding 'you are making a scene'." - Homer Simpson
10 replies so far
View lew's profile
lew
12500 posts in 3993 days
#1 posted 11-13-2009 08:06 PM
I use water based Poly.
View MrsN's profile
MrsN
987 posts in 3763 days
#2 posted 11-13-2009 08:14 PM
It is said that most finishes are non toxic once it has cured properly.
I use poly on toys that are probably not going to be chewed on. for something that is for a younger kid and has a higher chance of being chewed on I generally leave it unfinished or use a food safe finish
View LesB's profile
LesB
1918 posts in 3680 days
#3 posted 11-13-2009 08:18 PM
Water based poly works well. Also one of the salad bowl finishes like Behlen’s or General would also work. Make sure they dry for at least a week. If you make them out of hard maple they don’t really need a finish.
You could also just put a paste wax finish on them.
-- Les B, Oregon
View FatScratch's profile
FatScratch
189 posts in 3540 days
#4 posted 11-13-2009 08:19 PM
Shellac. It is not the strongest finish, but it is the most non-toxic finish, other than mineral oil, that you can use. The kids can chew away on it and you can be completely comfortable knowing it can not hurt them. Do a search on shellac and its uses, and you will be amazed.
View mtkate's profile
mtkate
2049 posts in 3562 days
#5 posted 11-16-2009 12:17 AM
Get the shellac flakes and make up batches for yourself (fresh). It’s fun stuff to work with. Dries super fast.
View grizzman's profile
grizzman
7836 posts in 3541 days
#6 posted 11-16-2009 12:37 AM
ive seen walnut oil…...ive used food safe minreal oil..but seem i read somewhere that its not safe for younger children…but cant remember where…..
-- GRIZZMAN ...[''''']
View SnowyRiver's profile
SnowyRiver
51457 posts in 3718 days
#7 posted 11-16-2009 01:20 AM
I would use blonde shellac. Like FatScratch said, its not quite as durable as poly, but its safe. They use it to coat food products.
-- Wayne - Plymouth MN
View cmaeda's profile
cmaeda
205 posts in 3791 days
#8 posted 11-17-2009 08:01 AM
I use shellac. If you have kids, buy the shellac in flake form because you’ll be using it a lot.
For some “nicer” things (like jewelry boxes and furniture), I also apply wax made of beeswax and coconut oil.
Kids also like color, so I use milk paint on most of the kids stuff I build and apply the shellac over the paint.
WAWoodButcher
#9 posted 11-24-2009 12:16 AM
Thanks for all the suggestions folks. I went with the water based poly on the rocking horse I did. Should be in my “projects” soon if you want to take a look. Thanks again
View Gary's profile
Gary
9386 posts in 3670 days
#10 posted 11-24-2009 12:48 AM
Rockler also sells a Toymakers Finish
