Hand Plane Jointing
Forum topic by Hawgnutz posted 10-12-2007 07:25 AM 9770 views 1 time favorited 8 replies Add to Favorites Watch
View Hawgnutz's profile
Hawgnutz
526 posts in 4041 days
10-12-2007 07:25 AM
Topic tags/keywords: plane-jointing
Here’s a question for all you gallouts out there: I have read somewhere that if you put the two boards you wish to edge joint side-by-side and then use a hand plane to joint the edge, any sloping of the plane will be canceled by the slope being shared by the two edges as they are planed at the same time. My question is: when you place the two boards side-by-side to plane the edge, do you have the face to face or face to back?
I need to glue up a panel, but my bench-top jointer is not giving me square edges. I don’t want to take the time, now, to align the tables, fences, and blades. (I will save that for the “winter” months.) If you can help me, it will save me having to dig through all my woodworking mags I have saved up….LOL
God Bless,
Hawg
-- Saving barnwood from the scrapyards
8 replies so far
View WayneC's profile
WayneC
13753 posts in 4062 days
#1 posted 10-12-2007 07:44 AM
Hawgnutz
#2 posted 10-12-2007 08:36 AM
Thanks, Wayne.
That is what I thought, but could not rememeber for sure. Working on wooden cover for wife’s ‘56 Ford.
God Bless.
Hawg
View Betsy's profile
Betsy
3391 posts in 3860 days
#3 posted 10-12-2007 03:10 PM
Hawg—- be sure to post a picture of the finished cover—sounds like an interesting project.
Betsy
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
View TomFran's profile
TomFran
2957 posts in 3959 days
#4 posted 10-12-2007 03:46 PM
This is good stuff! Thanks Hawg, for asking the question. This will help me out greatly.
I’ve been wondering how to do this for years. (I hate to admit that I was so knowledge deficient here…. ;^D )
View johnjoiner's profile
johnjoiner
160 posts in 3858 days
#5 posted 10-12-2007 05:03 PM
I prefer back-to-back instead of face-to-face. ;-)
Seriously, this method assumes the cutting edge of your plane iron is very flat/straight and not sharpened to a slight camber as is becoming more common with the teachings of David Charlesworth, Christopher Schwarz and others. I’ve attempted to draw a little diagram showing two boards edge-jointed with the top having an exaggerated angle, and a dashed line showing that surface if your plane iron has a camber (again exaggerated).
Please excuse this weak image
As you can (hopefully) see the edges of the boards which are in the middle during edge-planing will be lower if your iron has a camber. Then when you flip one board on top of the other those two edges are the ones that should meet, and they are shorter than if your plane iron is straight along the cutting edge. The result could end in your boards not being jointed parallel. I would guess, though, that in practice the effect might often be so small as to be negligible.
On the flip-side, if your blade iron has a camber, you’re in luck! The main purpose of that, as I understand it, is to make squaring of your edge easy. If the right side or your board is high, center your plane over that side, and you will take a shaving which is thicker on the right and thinner on the left.
Sorry if this is a tedious amount of detail here. I like hand-planing.
-- johnjoiner
Hawgnutz
#6 posted 10-12-2007 05:28 PM
Thanks, John.
I will be using either my steel #7, or an early wood version of the #7 to plane my edges These blades have no chamber. I have sharpened them with a flat edge for jointing planing.
I think one problem with clamping them back to back is that the exposed faces are exposed to possible clamping marks. I have modified my bench to accept wooden screw clamps along the front just for the purpose of planing edges. I have drawers mounted, so there is no room to mount a face vise, just a tail vise. I guess you get what you pay for. I bought my table at a discount supplier but it sure beats nothing!
Betsy, I willl be sure to post a picture of the tailgate cover/insert. Once i get the ttechnique ironed out, i will make one for MY ‘57, and sell them at car shows we will be frequenting. =);o))
God Bless,
Hawg
View Thos. Angle's profile
Thos. Angle
4444 posts in 3927 days
#7 posted 10-12-2007 05:38 PM
I guess I’ve never paid any attention to whether the boards were back to back or face to face. Just make sure that the insides of your vise are clean and there is nothing to mar the boards too deeply. I just might decide that the other face looks better after I glue them up. Besides I’ll be scraping and planing glue lines any way. I’ve been able to achieve invisable glue lines with this method.
View oscorner's profile
oscorner
4563 posts in 4275 days
#8 posted 10-12-2007 06:16 PM
Good question Hawg! I’ve had success using this method.
-- Jesus is Lord!
