New Woodworker Glue-Up Question
Forum topic by jjbuckeye posted 11-13-2009 06:05 AM 1058 views 0 times favorited 6 replies Add to Favorites Watch
View jjbuckeye's profile
jjbuckeye
11 posts in 3240 days
11-13-2009 06:05 AM
I’m making my daughter an Armoire for her American girl doll for Christmas. The piece will be 27 inches high, 22 inches wide and 9 3/4 inches deep. It will be made out of solid cherry. Most of the piece will 1/2 inch thick (including the shelves which are 10 inches wide). I cut out dados for the shelves and I’m curious how I should attach the shelves to the case sides so there are any issues with the wood splitting. Should I put glue on part of the dado?? Should I bypass glue all together and drill holes through the outside with screws into the shelves and plugs?? I probably could have used plywood and not worried about this issue but I wanted it to be solid wood.
Probably a simple question but I wanted to do it right so I didn’t have issues years down the road. I’m hoping this is something she keeps and passes down some day.
Thanks in advance,
Joe
View Moron's profile
Moron
5032 posts in 3856 days
#1 posted 11-13-2009 06:10 AM
if the shelves grain direction matches that of the sides then both sides and shelves will shrink and expand at the same rate, so gluing them together shouldnt be an issue.
View Rabbet's profile
Rabbet
35 posts in 3104 days
#2 posted 11-13-2009 06:38 AM
You could glue the first couple of inches on the front so the back half will slide(Just to be safe). Or you could do the whole shelf with a sliding dovetail with glue on the first inch or so.
-Rabbet
View mcase's profile
mcase
446 posts in 3092 days
#3 posted 11-14-2009 12:51 AM
If its only 9 3/4” deep this should not present much of a problem. The problem is that the joint is all end grain and glue will not hold. Rabbet is right about the sliding dovetail. A sliding dovetail provides a physical joint that is ideal for this application. Personally I would not recommend a new woodworker try this out as it is a difficult joint to get right. Also it sounds like you already cut the dados. Not to worry though. I made a lot of bookcases for myself and friends back when I was in school (don’t ask how long ago). Suffice it too say they held up over the decades. I made them out of 1×10” pine with dados and screwed them together and capped the screws. I hope she enjoys the armoire
jjbuckeye
#4 posted 11-15-2009 07:15 AM
Thanks for all the good information. The armoire is turning out very nice.
Joe
View BTKS's profile
BTKS
1986 posts in 3427 days
#5 posted 11-16-2009 01:46 AM
Do we get to see pics of the armoire? I hope so. BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
Todd A. Clippinger
8901 posts in 4062 days
#6 posted 11-16-2009 02:07 AM
Roman is exactly right about the orientation of the pieces and the wood movement.
