Trying to identify a Router Edge
Forum topic by AtTheHelm posted 09-04-2015 02:53 AM 739 views 0 times favorited 6 replies Add to Favorites Watch
View AtTheHelm's profile
AtTheHelm
2 posts in 1021 days
09-04-2015 02:53 AM
All,
Looking for some help… Have to match the edge in the image attached, and unsure what you would call the bit or if it would be 2 separate bits to achieve it. Just the outer edge is what I’m talking about. Any help would be great. First post, so let me know if I’m not giving enough detail and or approaching looking for help incorrectly.
Thanks,
TH
View Richard H's profile
Richard H
489 posts in 1705 days
#1 posted 09-04-2015 03:15 AM
Whiteside has a online catalog of bits where they show full size profile views. I can’t tell from the picture for sure but it looks like a pretty standard profile to me. Maybe the wavy edge bit on the below page?
http://www.whitesiderouterbits.com/catalog.html
AtTheHelm
#2 posted 09-04-2015 03:28 AM
Richard, Thanks for the site link.
I’m new to the varying types of profiles… but the one that I’ve pictured above is probably twice as wide as it is deep. The “Wavy Edge” on that link is very deep but not very wide. Now that being said, maybe there are varying measurements you can get a wavy edge in that would then replicate it (again, my newness to all of this may be the deficit). But the one pictured would be too deep and not wide enough. And what are the terms you’d use to define the depth vs. width etc. as you try and describe/match something like this?
Thanks again for the help.
View bruc101's profile
bruc101
1200 posts in 3567 days
#3 posted 09-04-2015 04:48 AM
We do solid surface countertops and we use different size cutters and drop edge build ups to get the size profile needed.
That profile can be called wavy edge and ogee depending on who makes the cutter and what you want to call it and what they want to call it and the size of it. I think maybe a large ogee cutter would give it to you. If you have a small one run and edge on a piece of scrap and see if it looks like it. It actually looks more ogee to me without the bead.
-- Bruce Free Plans http://plans.sawmillvalley.org
View pjones46's profile
pjones46
1001 posts in 2668 days
#4 posted 09-04-2015 05:27 AM
Looks like a CNC simulated-raised-panel…router-bit….#2481 from Toolstoday.com used as an edge treatment.
-- Respectfully, Paul
View jerryminer's profile
jerryminer
928 posts in 1466 days
#5 posted 09-04-2015 06:05 AM
Also similar to Whiteside’s “plunge ogee” in the “Groove Profiling” category (from link above)
View cabmaker's profile
cabmaker
1735 posts in 2834 days
#6 posted 09-05-2015 12:49 AM
cove and bead….not to be construed as bead and cove.
