| Forum topic by jockmike2 | posted 780 days ago | 319 views | 0 times favorited | 1 reply | ![]() |
780 days ago |
Here’s a way to get one or maybe two more cuts out of that board. Using a scarf joint. What is a scarf joint, you say. Just make a jig with a 20 degree angle on it. Lay it on your board in the middle, using your circular saw make a long cut on the angle you just drew using a straight edge.. Next using your router, make a clean cut on both long cuts to joint both angle cuts. For every One inch in length you gain in length, you sacrifice 7/16 in width. -- Mike. mwurm13@yahoo.com |
