pofessional advice needed
Forum topic by sprunk86 posted 09-03-2015 05:08 PM 711 views 0 times favorited 5 replies Add to Favorites Watch
View sprunk86's profile
sprunk86
2 posts in 1146 days
09-03-2015 05:08 PM
Hello. I have an idea for a type of engineered hardwood flooring. Instead of the planks having straight edges, they would have curved edges and form a repeating pattern. This is something I want to build myself or with the help of a manufacturing company, and eventually build a business around it.
I have been visiting flooring retailers in my area hoping they could put me in touch with someone who has knowledge of engineered flooring manufacturing process. So far no one has been able to help, so I’m turning to the internet for help :-)
I imagine engineered hardwood is laminated in large sheets. So my idea was to use a water jet to cut the design then add a tongue and groove with a router.
Here are some question i have…
-The core in engineered hardwood – I have seen some brands with just a single layer of some type of fiberboard, and other brands with multiple layers of cross-grained veneer? What is the advantage of one over the other?
-What type of glue do they use?
-What’s the maximum thickness of cut that can be achieved using the rotary cut veneer method, I would like to use a 1/4” wear layer.
-Should I be worried about swelling from the water in the waterjet cutting process?
-Would it be possible to impregnate the wood (a resin maybe, silicon) to minimize dimensional instability due to humidity fluctuations?
Any questions or comments you may have are welcome.
I’ve included a picture of a few sketches to give you an idea of what I have in mind.
5 replies so far
View IHRedRules's profile
IHRedRules
115 posts in 1625 days
#1 posted 09-03-2015 05:19 PM
I would recommend that you do some research on patents, to see if there is already something out there that might have an impact on your ideas before you spend a lot of time on this.
View mahdee's profile
mahdee
3993 posts in 1916 days
#2 posted 09-03-2015 05:24 PM
I think whatever pattern is used must be in a way that eliminates or minimize waste. So, once a cut is made, the board is turned around and cut in a way to match the previous cut. However, the patterns you have posted can be created wooden tiles using CNC. The grooves or spaces resulting from the blade could resemble spacing between the two patterns. This would eliminate gluing and movement of the boards.
-- earthartandfoods.com
mahdee
#3 posted 09-03-2015 05:54 PM
On March 25th, 2010 in Washington DC, Czar Floors was awarded The Best Floor of The Year in CNC/Laser Cut category.
sprunk86
#4 posted 09-03-2015 10:48 PM
Hello mrjinx007, I am having trouble understanding what you mean. Could you explain it in a little more detail, I am familiar with CNC, so go ahead and use technical terms if you wish. Also what is the actual cutting method you would recommend?
edit: Just noticed it said laser cut in the description, how would they get rid of the burn marks though.
mahdee
#5 posted 09-04-2015 12:44 AM
I believe the burn marks are the defined lines you see. I am just guessing at that but it makes sense to me. I bet you can call them and inquire:
Are the designs painted on the wood surface?
Not at All. We do not use paint to create inlay designs. Every pattern is made up from different wood species, carefully matched by the designer to achieve the desired color effect, inlaid. From the picture below, you can see the edge of the B5 border. Top wood layer has different woods cut and inlaid to form a pattern. It is mounted on the plywood backer for 3/4” thick product.
