Something new in my woodworking--I broke a chisel
« back to Hand Tools forum
Forum topic by CharlesA posted 09-03-2015 01:55 AM 2172 views 0 times favorited 44 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3322 posts in 1798 days
09-03-2015 01:55 AM
I’ve had a set of Irwin Marples Chisels for about 3 or 4 years. I was chopping some mortises in QSWO tonight, and all of a sudden, the blade was in two pieces, the break an almost perfect perpendicular. Any thoughts?
44 replies so far
View BurlyBob's profile
BurlyBob
5494 posts in 2266 days
#1 posted 09-03-2015 02:00 AM
Gotta be some kind of defect in the metal. Was it one of the new and improved chisels from China? Either way that really bites.
View TheFridge's profile
TheFridge
9482 posts in 1486 days
#2 posted 09-03-2015 02:18 AM
Sharpen it up and put it back to work.
View Clarkie's profile
Clarkie
453 posts in 1841 days
#3 posted 09-03-2015 02:30 AM
Start using a mortise chisel. rut ro
TheWoodenOyster
1317 posts in 1935 days
#4 posted 09-03-2015 03:24 AM
My only thought is that is weird.
-- The Wood Is Your Oyster
View nailbanger2's profile
nailbanger2
1041 posts in 3143 days
#5 posted 09-03-2015 04:37 AM
My thoughts are you were hitting that poor chisel too hard, Charles. I’m going to have to make some tips out of Charmin for mine, as I have the same kind.
-- Wish I were Norm's Nephew
View mahdee's profile
mahdee
3883 posts in 1768 days
#6 posted 09-03-2015 11:03 AM
The mighty oak can do that.
-- earthartandfoods.com
View Redoak49's profile
Redoak49
3250 posts in 1989 days
#7 posted 09-03-2015 11:34 AM
I can guess at the cause if you give a good close up picture of the fracture surface. Also, were there any small nicks on the sides?
When trying to figure out why or how something fractured, a good picture of the fracture face is most important.
View bearkatwood's profile
bearkatwood
1572 posts in 1012 days
#8 posted 09-03-2015 11:41 AM
You are becoming stronger grasshopper.
-- Brian Noel
View BubbaIBA's profile
BubbaIBA
387 posts in 2377 days
#9 posted 09-03-2015 12:24 PM
From the photos and where the break occurred I’m making an assumption that you were “levering” against the back not the bevel edge. I also expect there was a fault in the chisel but without a image of the fracture that is an assumption. Even with a robust mortise chisel like an English pig sticker the levering should use the bevel as the lever point. Using the back will put the stress point higher up the chisel resulting in a longer arm and greater stress at the lever point.
While bevel edge bench chisels can be used for mortices (I will on occasion) a better option is to use a mortice or sash mortice chisel. They have evolved over time for just that job. With a bench chisel you need to take smaller cuts than with a mortise chisel with more room to lever the waste
ken
CharlesA
#10 posted 09-03-2015 12:31 PM
I was looking back on why I had decided I didn’t really need mortise chisels for my occasional mortise work and came upon an article by no less than Paul Sellers that suggested exactly that. I was cutting one far deeper than usual and started to really yank on that chisel. I finished up with an Aldi chisel I bought as a backup. I immediately noticed that the Aldo blade was thinner and bendier, so to speak.
I already figured it was mostly my fault, but I am surprised that it broke so cleanly.
View boisdearc's profile
boisdearc
44 posts in 1336 days
#11 posted 09-03-2015 02:03 PM
I am sure Marples will warranty that…
View TheGreatJon's profile
TheGreatJon
337 posts in 1234 days
#12 posted 09-03-2015 02:08 PM
“Control, control, you must learn control!”
-- This is not the signature line you are looking for.
View HokieKen's profile
HokieKen
5017 posts in 1139 days
#13 posted 09-03-2015 02:21 PM
Look for beech marks on the fracture face. They’ll look kinda like growth rings in a tree. If they’re there, then there was a weak point in the steel that propogated out over time until the break occurred. If there are no beech marks, it was probably a brittle fracture that occurred suddenly. Either way, I’d think the manufacturer would cover it under warranty. But, if it was a fatigue fracture and has evident beech marks, it was a material flaw and they should most definitely replace it.
-- Kenny, SW VA, Go Hokies!!!
View Sylvain's profile
Sylvain
706 posts in 2499 days
#14 posted 09-03-2015 03:09 PM
It seems you first drilled a hole before using the chisel, something which is not part of the Paul Sellers method.
I have used the PS method to chop mortises 8 cm deep X 10 mm wide X 6 cm long (in fact 4cm because it was through and I flipped the board) with a no-name beveled chisel, bought a few Euro on a flea market, without any problem.
If you look carefully to the video where he does two mortises behind a glass, one with a mortise chisel and the other with a beveled chisel, you will see that the bevel of the chisel acts as a wedge, producing a shear force which split the wood along the mortise wall. Practically no leverage action is needed; except to clean the waste.
One has also to listen to the sound, the sound changes at the last tap before the next move, don’t make an extra whack.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View JohnChung's profile
JohnChung
408 posts in 2074 days
#15 posted 09-03-2015 03:41 PM
I would say that the chisel was faulty. If the chisel failed, there would at least be a bend on it first.
showing 1 through 15 of 44 replies
