fixing old bandsaw
Forum topic by harum posted 09-02-2015 11:22 PM 1250 views 0 times favorited 9 replies Add to Favorites Watch
View harum's profile
harum
285 posts in 1668 days
09-02-2015 11:22 PM
Topic tags/keywords: band saw motor pulley pulley replacement spare parts
I am trying to get to work my neighbor’s bandsaw which hasn’t been in use for about 10 years. I went through the manual, changed the blade and adjusted the tension, the guards and such things. The saw worked reasonably well for a few minutes until it started to vibrate with quite a noise and shaking.
This is why:
One side of the motor pulley almost completely crumbled!
Was wondering if this was just because of the saw age or I missed something in my check-up, like motor belt tension or pulley position? And what is a good resource for band saw parts?
This is a Jet JBS-14:
Also, is this the correct orientation of the plastic blade cover at the back of the saw, like here?
Would appreciate any suggestion or comment! Thanks and best wishes, h.
-- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time."
9 replies so far
MrUnix
6766 posts in 2224 days
#1 posted 09-02-2015 11:31 PM
Probably just from age/abuse. You can get a new one any number of places… McMaster Carr, Grainger, MSC, Tractor Supply, Ace Hardware, etc…
Looks like it’s on backwards to me… the opening should face forward, as otherwise changing blades will be a royal PITA and you will have to remove the guard each time you do.
harum
#2 posted 09-02-2015 11:42 PM
Thanks, Brad!
View gfadvm's profile
gfadvm
14940 posts in 2715 days
#3 posted 09-03-2015 02:37 AM
The guard on my old Ridgid is like that and has to be removed to change blades. And no other way to modify or install it.
MrUnix
#4 posted 09-03-2015 02:47 AM
How is it attached? Are you sure you can’t flip it around/upside down? I’ve never seen one that required removal for a blade change by design… but I have seem them like that when the guard was installed improperly. It’s very easy to do (flip around the wrong way) on the stock 14” Delta clone type machines.
gfadvm
#5 posted 09-03-2015 02:58 AM
Brad, Mine is held on with screws on the left hand, front side of my old gray Ridgid. I have not found a way to mount it where the blade can be changed with it on there. PITA but I don’t like looking at that exposed blade running above the table.
harum
#6 posted 09-03-2015 03:03 AM
- gfadvm
I have found the guard fits okay both ways and, when changing the blade, once the wheel covers are removed the guard is just pulled out, no extra fasteners to be removed or anything.
If I put the guard as in the photo, the blade doesn’t rub it at all.
What are good online stores for replacement parts like this one? Looks like Jet discontinued the original pulley.
MrUnix
#7 posted 09-03-2015 03:16 AM
The sources I gave above all should have a suitable replacement.. it’s just a pulley… nothing special or “Jet” about it. Just measure the outside diameter and bore size and find one the same size.
PS: It’s never a good idea to buy replacement parts from the manufacturer that are standard hardware store items. I’ve seen $0.10 bolts being sold for over $10 just because it was ‘branded’ with the manufacturers packaging. Cheap Chinese bearings being sold for over $30 by the manufacturer, where quality ones can be had from a bearing supplier for $4. You get the idea :)
harum
#8 posted 09-03-2015 03:41 AM
You get the idea :)
- MrUnix
Yes, thanks!
harum
#9 posted 09-07-2015 02:10 PM
Ended up ordering the motor pulley, or sheave, on the internet for about five dollars. After I’d brought the broken part to several retail stores and been shown clothesline pulleys as an option I went straight to Amazon for exact replacement. Thanks Brad and gvfadvm for the suggestions and comments.
